Old 08-26-2011, 06:21 PM   #1
jfaplanet
1979 s5-sa
1979 SA
Build date Sept 1978.
FC front subframe w/ manual rack
5-lug conversion
S5 NA engine with stock electronics
So I bought this SA from a friend who bought it from a guy in Jersey that had done some suspension work to it and then decided to ditch the project for VW's and completely get out of the 7 business. The car came with a Re-Speed rack, GSL-SE rear end, and lots of RE-Speed suspension parts.
Well being that I already have one SA that is modified with SE suspension, I decided to put the rack and springs and shocks on my other SA. Some of you have seen it at Deals Gap, the red and black SA-SE. Back to the story. My daughter has a 04 winning blue RX-8, and also had built a S5 motor for her 91 coupe, but decided that she liked SA's a lot better. So this is where the story gets good.
We decided to put a FC subframe in the SA, many of you have seen it done on the evil forum and so that is where we got our inspiration. Now the FC front subframe will be able to accept the S5 motor without any modifications to the front cover or oil pan. The s5 ecu and harness are retained and fused using a fuse block out of a FB placed inside the center console. Also included is the check engine light for diagnostics. ECU mounts nicely to the passenger side kick panel. The rear of the car had been modified for a panhard bar and did away with the watts link. Battery had already been relocated to behind the pass seat. FB bins hide the battery and allow for some storage. Adapters allow the FC wheels to fit on the rear, with t2 brakes in the front. Stock FC sway bar fits nicely and allows for the FC radiator to be mounted very much like an FC's. I have been working on the car for about a year now and have had lots of help from fellow Rotor heads in my area. Thanks guys you know who you are.
When finished this will be my daughter’s car to drive on weekends and play with when she doesn’t want to drive the 8. She has not yet decided what color to paint the car. Her goal is to one day do a S5 turbo swap into the car.
