Old 08-21-2011, 11:21 AM   #1
TheDriver216
TheDriver216's Avatar
rear end noise
I just installed a 83 gsl rear end into my 82. Ive noticed when i make sharp slow right turns on occasion it feels like the right rear wheel is kinda stuttering and dragging.. Is that just teh LSD chattering? it only does it on right turns.. my next thing ill do is im going to replace the diff fluid and see if that helps. Any suggestions on fluid type? Any other opinions on what is the issue?
Old 08-23-2011, 05:11 PM   #2
eprx7
eprx7 is on a distinguished road
it sounds to me like lsd rear chatter. change your fluid to red line fluid I think its gl-4 fluid but I'm not 100% sure check your owners manual or service book. I just used the redline with now lsd additive, I have used it in the diff for over 8 yrs and it see a lot of track time and auto-xing. goood luck hope it helps.
1979 SA F Prepared solo/ Track day car 12a w/Weber carb,RB header and exhaust,
Ground Control coilovers, camber/caster plates
GforceEng.panhard rod w/ tri-link,Panasports wheels w/Hoosier slicks.
eprx7 is offline   Reply With Quote
Old 08-24-2011, 08:31 AM   #3
Kentetsu
Kentetsu's Avatar
Yeah, I agree with the chatter diagnosis. I used Lucas in mine, better than Royal Purple.
