Old 08-10-2011, 01:24 PM   #1
Boosted FC
Rotary & Boost Addict
Boosted FC's Avatar
Boosted FC is on a distinguished road
Vacuum source for Brake Booster
Hey guys. Have a S4 T2. Just swapped out to a S5 upper intake manifold. On the S4 mani there were 4 ports on the back, the biggest whicj went to the brake booster. On the S5 there are only 2 ports, 1 small and the other just a tad bigger (not as big as the port on the S4). I used the bigger port for the booster, but just took the car for a drive and the pedal is hard and the car barely wants to stop. Is there somewhere else I should use for the vacuum source? And does the hose material that I am using matter? (Using 3/8" heater hose). Thanks.
-Sheldon.
'05 Copper 6s, '87 TII RX7...248whp & 224wtq @ 12lbs
Boosted FC is offline   Reply With Quote
Old 08-10-2011, 08:55 PM   #2
The largest port on the back of the intake manifold is the one you need to use for the brake booster. By any chance did you discard the original stock hose without saving the plastic 1-way check valve that was inside it for reuse in the new hose? You'll need that for proper brake booster operation. On the S5T2, that check valve is located inside the stock hose on the brake booster end, probably the same location on the S4.
Old 08-10-2011, 09:00 PM   #3
Boosted FC
Boosted FC's Avatar
Yeah, the check valve is still there.
Old 08-10-2011, 09:10 PM   #4
Were the brakes working fine before the booster hose was changed? If so, another possibility is that the check valve was reinstalled backwards, which would prevent the booster from holding a vacuum.
Old 08-10-2011, 09:52 PM   #5
I believe the largest fitting of the fittings inline on the back side (facing the firewall) of the upper intake manifold is for the oil injectors?
If so, this fitting is sourced BEFORE the throttle body, which means it will NEVER see vacuum.
This explains why your brakes are not working properly.
The brake booster needs to source vacuum AFTER the throttle body.
I believe this fitting to be at least 10mm?
Old 08-11-2011, 12:30 AM   #6
I just checked my Zenki FC turbo...
The brake booster fitting is on the surge tank of the upper intake manifold.
It's offset towards the passenger side of the car facing the firewall.
This is for US-spec engines.
It's basically the lowest fitting back there.
For J-spec upper intake manifolds, there's a short banjo to pipe fitting that comes off the lower intake manifold right over the turbo.
This is to compensate for the RHD design which locates the brake booster on the opposite side of the firewall.
Old 08-11-2011, 07:08 AM   #7
Boosted FC
Boosted FC's Avatar
Damn, I wonder if I ended up getting a JDM manifold. I'll take some pics and post later. Thanks guys.
Old 08-29-2011, 10:07 PM   #8
Boosted FC
Boosted FC's Avatar
Sorry for the late pics. I am using the nipple at the top of the intake manifold for the vacuum source. The nipple where the little formed hose comes off and goes to the IC. So far everything is good.
