Old 08-02-2011, 02:35 PM   #1
Tj1056
Tj1056 is on a distinguished road
P/S pulley removal help plz!
well I have been trying to remove the pulley bolt but I tried to clamp it down but the plastic is to brittle and just brakes... I ordered a billet pulley for replacement but am having trouble getting this bolt off... and I cannot get a hold of a the SST the shop manual calls for... any help would be great!
1993 Base model rx-7 13B FD3S
Greddy intercooler, Greddy bov, Efini(99+ spec) twin turbo & y pipe, Power FC and Commander, Short shifter, Koni adj. struts, Bönez Stainless DP, RP Competition Fuel Pump, 1300cc secondary injectors, M2 Performance air intake
Tj1056 is offline   Reply With Quote
Old 08-02-2011, 10:46 PM   #2
You're talking about the center bolt that holds the pulley on right? Have you tried an impact gun? With the impact gun you shouldn't need to hold the pulley while loosening the bolt. That's what I used on the stock pulley before.
Old 08-02-2011, 11:16 PM   #3
Tj1056
I got it off... kept fucking with it and it cracked so I hammered a flathead though it and it split right off lol... O I have a question about the A/C now... my dealership shop manual does not go into a lot of detail about removing these things... how many bolts hold the A/C on? I got 2 long ones off the top but I cant find anymore...
Old 08-03-2011, 07:19 AM   #4
Garfinkles Motor Works
Remove the water pump pulley to find the other bolts and nuts .
Old 08-03-2011, 08:47 AM   #5
cewrx7r1
The Judge
The shop manual shows all. Have you even looked at it?
That is where every novice SHOULD start.
Old 08-03-2011, 03:22 PM   #6
Tj1056
Did you read what I wrote? I said the dealership shop manual does not go into detail very well... all it says is remove P/S and A/C ... does not even show that I need to remove the A/C pulley...
Old 08-04-2011, 12:56 AM   #7
Tj1056
Okay I found out through another source that there are 2 more bolts underneath the ones that I got... have to hoist out the engine a bit to get to them tho...
Old 08-04-2011, 09:15 PM   #8
hades
The engine bay is tight, but I doubt hoisting the engine is standard service protocol to repair or replace the A/C compressor. Other parts may need to come out though.
By any chance have you downloaded the factory service manual yet? If not I would stop where you are.
This is going to tear
Old 08-05-2011, 12:30 AM   #9
The two bolts on the bottom of the AC compressor are the same as the two on the top, so they will not come out completely until you get the engine high enough that the compressor can be pulled to the side. However, you can take off the AC and PS bracket I believe to get it out all the way without lifting the engine at all or removing it, but I don't remember for sure. Either way, it's a PITA haha.
And you don't remove the AC pulley from the compressor, leave it on. It doesn't keep the compressor from coming out.
Old 08-05-2011, 05:47 PM   #10
Tj1056
yea the only problem with getting the bracket off is one of the top bolts is blocked by the curves of the bracket and the P/S... and yea I figured not to pull the A/C pulley ... just a few more things and its coming out.
Old 08-05-2011, 05:50 PM   #11
Tj1056
um thanks for the advise but I am not repairing or replacing the A/C compressor and I have a OEM dealership workshop manual... I know the majority of the engine... I just have never needed to pull this engine yet...
Old 08-06-2011, 01:06 AM   #12
I'll have to take a look again, I don't remember anything blocking those bolts. Hmmm
Old 08-25-2011, 09:34 PM   #13
jkstill
jkstill is on a distinguished road
I wrapped the belt around the pulley, held it with my left hand and used a socket wrench to remove it. Using an impact gun may have made it easier.
I have the billet pulley you speak of. Make sure it fits properly. Mine needs some slight modification - it cannot go back far enough to line up the belts properly. Not too difficult to fix, but something of an annoyance.
jkstill is offline   Reply With Quote
power steering, pulley, removal
