Old 07-28-2011, 08:31 PM   #1
tyler
crazy previous owner
Ok guys so I finally got the $ saved up for my rteck and I take the car out before I let it sit. It starts acting crazy, gets stuck in gear revs and bucks. Needless to say I decided to wait on the rtek. The other day I went back to the previous owner to question hm abot his mod. After a few hbours I figured out the problem and told him of my plans. He then told me that the ecu has alredy been "chipped". He said it has a reedom chip. Now I've looked and looked but can't find anything about this. Can some one tell me what the hell he is refering to?
Old 07-29-2011, 05:35 AM   #2
If it's for real...
"REDOM"
It's R.E. Amemiya's line of reprogrammed ECU's.
If you have to ask who "R.E. Amemiya" is then...well...
Old 07-29-2011, 02:01 PM   #3
tyler
I know who they are I justcouldnt come up with anything on my searches...thanks for the help
Old 07-29-2011, 03:08 PM   #4
tyler
Okay today I decided to pull the ecu out and I could barely make out a redom sticker. But couldn't see the sticker that should say what trhe ecu is flashed for. Anyone have a way to tell even what type it is?
Old 07-29-2011, 10:21 PM   #5
Open the ECU case up.
There should be a sticker on the EEPROM chip.
Old 07-29-2011, 11:20 PM   #6
tyler
Thanks again!!!
Old 07-31-2011, 10:12 PM   #7
tyler
Hey sorry for some many q's RETed but I can't find any info in english. I opened up the case and found a metal redom tag over the chip but nothing else. Would the be some form of id number under the tag?
Old 08-01-2011, 03:23 AM   #8
Sometimes the Japan shops will stamp the label with info about the chip like "hi boost" or something like that.
Other times it's just a "version #".
It sounds like yours is just a version #.
With that said, there is very little you can do with a stock ECU reprogram.
Automatic is the elimination of the overboost fuel-cut.
I doubt fuel is tweaked very much, as this isn't very easy to do.
Typically, they adjust the ignition timing to run a little bit more aggressive.
Sorry I can't give you more info other than that.
R.E. Amemiya will not answer any questions unless you can talk to them in Japanese.
Old 08-01-2011, 10:06 AM   #9
tyler
Thanks yet again you've been a lot of help! Well it looks like I'm still going to have to swap out for an rteck but now I need a stock ecu as well
Old 08-01-2011, 06:41 PM   #10
j9fd3s
yeah they have a couple/few different levels. the base like ted says is just removing the fuel&speed cuts.
there is an english reader there, you can click on the english email flag, but unless there is a serial type number on the ECU, they may not be much help.
-mike
Old 08-02-2011, 06:01 PM   #11
tyler
Thanks ill try and get ahold of them and see what I can find out
