Old 07-24-2011, 03:06 PM   #1
Tj1056
Tj1056 is on a distinguished road
Broken seat tips on removal.
Well my passanger seat on my FD is somehow broken and stuck in the furthest back position it can be in... all the way up against the plastic storage bins and cant even stick my fingures between it... any tips on how to get to the rear bolts?
1993 Base model rx-7 13B FD3S
Greddy intercooler, Greddy bov, Efini(99+ spec) twin turbo & y pipe, Power FC and Commander, Short shifter, Koni adj. struts, Bönez Stainless DP, RP Competition Fuel Pump, 1300cc secondary injectors, M2 Performance air intake
Tj1056 is offline   Reply With Quote
Old 07-25-2011, 11:06 AM   #2
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Can you removed the back piece from the seat itself or does it have to come out as 1 unit?
Old 07-26-2011, 08:27 PM   #3
widebodyse7en
corvette eater
widebodyse7en's Avatar
widebodyse7en is on a distinguished road
hey tj there should be a rod that connects both sides of the rail and if you disconnect that it will unlock the mechanism so you can slide it ( you will still need to use the handle on the seat because the one side will still be able to lock)
WideBodySe7en NOW ACCEPTING REBUILDS!! pm me for pricing
widebodyse7en is offline   Reply With Quote
Old 07-30-2011, 10:46 AM   #4
Signal 2
Viable Fossil
Signal 2's Avatar
Late to the thread, but would one of these help (Gearwrench w/optional socket pictured at bottom)? I love these damn things. They'll get into some pretty tight places.
Jim
VR R1 FD
Old 08-13-2011, 02:55 PM   #5
cewrx7r1
The Judge
The handle to disengage the slider directly works on it's side.
It pulls a wire attached to the other side to disengage it.
I can not imagine any other failure then the wire coming off or broken.
The rest of the mechanism is too strong to have been easily broken.
Take your other seat out and investigate how it works.
Then you SHOULD be able to figure how to resolve your problem.
