Old 07-20-2011, 08:28 AM   #1
Exclamation Help making custom oil lines for turbo
So, I am scratching my head a little here. I have been searching around for info on how to build, or flat out purchase oil feed/return lines for my 12a turbo project.
Keep in mind, I am NOT using a 13B, and do not have the factory lines at all.
I will get my feed source from my RE-Speed pedestal, return will go to the front cover, in the same place as a stock TII (front cover drilled and tapped).
I am using a stock S4 turbo.
Any info/parts list would be greatly appreciated. This is the last piece of my puzzle.
Please keep in mind I am a cheap bastard, and this is a test project. Not looking to spend a fortune on this
