Old 07-17-2011, 01:06 PM   #1
rxbrooks7
rxbrooks7 is on a distinguished road
i want a 13B-RE
well i want to put an RE in my FC but what all will i need to do such a swap i know banzai racing has the motor mounts to do it but will i be able to use my T2 trans will i need a new ECU can i use a PFC lol
rxbrooks7 is offline   Reply With Quote
Old 07-17-2011, 02:36 PM   #2
You can use your trans. You'll need the appropriate clutch/flywheel/counterweight though.
You will need a better ECU. Standalone.
Old 07-17-2011, 03:45 PM   #3
WankelsRevenge
WankelsRevenge's Avatar
Im thinking about getting this swap done as well. Unfortunatly I dont have the same contacts I used to. What are some good places that offer motors/rebuilds?
Ryan
Old 07-17-2011, 04:43 PM   #4
rxbrooks7
well i have sound everything other than the flywheel and clutch and counter weight any ideas
Old 07-17-2011, 04:43 PM   #5
rxbrooks7
found lol
Old 07-17-2011, 08:29 PM   #6
Ryan
Illicit Performance. Can do the entire swap for you as well.
FWIW I have the Banzai mounts, I wouldn't reccomend them, ever. Going to be probably building my own soon.
Old 07-17-2011, 09:48 PM   #7
rxbrooks7
well what would you charge me for a set of motor mounts lol
Old 07-17-2011, 09:57 PM   #8
I need your car, and your engine, and I'm not taking on any new projects until November unless I get my slate cleaned. PM Mazpower on this board about the rebuild though.
Old 07-18-2011, 12:39 AM   #9
WankelsRevenge
Ill have to check em out. Ideally Id like to order one from a place and have them do a rebuild and a mild dtreet port on it. Im deffinatly gonna do some shopping around though to see what I can find.
Ryan
Old 07-18-2011, 01:51 AM   #10
rxbrooks7
well i told the guy with the RE that i want it so ill have time to work all my buggs out hope there wont be too many
