Old 06-27-2011, 01:09 PM   #1
fc nut
member
rew swap in an fc
is there a thread on this swap somewhere here? i'm thinking of swapping in a third gen engine in my fc. i need info.
Old 06-27-2011, 01:38 PM   #2
tyler
Have you read this webpage? http://fc3spro.com/TECH/SWAP/FD3S/rew.html
They outline what needs done
Old 06-27-2011, 01:45 PM   #3
tweiss3
Mazda Lover
tweiss3's Avatar
Also TitaniumTT did this to a point. There is a shit ton of subframe fab work.
Old 06-27-2011, 02:20 PM   #4
fc nut
member
i know it's gonna be a job, but bonzai in indy has the mounts. i was wandering if you use the fd trans or an fc. i'm looking for details on the subject. if it's gonna be too much, then i'll stick with the t2 engine that came in the fc's.
Old 06-27-2011, 02:30 PM   #5
tweiss3
Mazda Lover
tweiss3's Avatar
PM TitaniumTT
Old 06-27-2011, 02:42 PM   #6
Mazdabater
FC3S
You can use the fc trans it bolts straight up.
Old 06-27-2011, 02:43 PM   #7
fc nut
member
will do,thanks.
Old 06-27-2011, 06:25 PM   #8
Dzire
Dzire's Avatar
Dzire is on a distinguished road
those motor mount brackets are for the 13b RE they will not work for the 13 b REW as far as the transmission goes the turbo II tranny will work
RX8 2004 GT
RX7 1988 TII
Dzire is offline   Reply With Quote
Old 06-27-2011, 09:02 PM   #9
Any mounts that adapt the REW engine to the FC chassis are worthless. Anyone who is familiar with the REW mounts and the FC chassis know why.
Basically it loads the mounts in a way they were never meant to be loaded. The only way I would consider doing that swap involves alot of welding on the FC front crossmember
Old 06-27-2011, 09:27 PM   #10
Dzire
Dzire's Avatar
TTT he is correct I've seen 3 different styles break under hard loads
RX8 2004 GT
RX7 1988 TII
Old 06-28-2011, 06:51 AM   #11
fc nut
member
would a cosmo be a better swap or just use a s4 t2 engine.my goal hp level is about 350 at the wheels. it's an n/a s4 right now. i'm not swapping anything just yet. this fall i'll be stripping the whole under side of the car removing any and all rust from it. i plan on having everything blasted and painted before i put it back together. once i get everything underneath done, i'll then focus on what i'm gonna put under the hood. i'm trying to find out what my options are when i get to that point. the help you're giving is much appreciated.
Old 06-28-2011, 10:20 AM   #12
For 350whp I dont see the point in going beyond the 13BT
Old 06-28-2011, 08:25 PM   #13
fc nut
member
after i thought about it at work today, it would be less of a hassle to go that route. i must've had some kind of a brain fart. thanks for the input though guys.
