Old 06-13-2011, 12:53 PM   #1
one320fc
one Apex @ a time
one320fc's Avatar
Motor difference between years??
I was looking at RBs ignition spread sheet and it calls for different timing between 79-83 and 84-85 12A
1983 Limited Edition SOLD
1977 Mazda REPU I will work on it one day I sware!!
1987 T2 um after the repu is done??
2013 Chrysler 200 DD
2009 Dodge Journey
94 Volvo 850 N/A The slowest car I have EVER owned!!!
Old 06-13-2011, 04:06 PM   #2
Might have something to do with the older points style dizzy's versus the electronic ones.
Just a guess.
Old 06-13-2011, 05:43 PM   #3
one320fc
one Apex @ a time
one320fc's Avatar
Yea thats what I was thinking but figured I would ask..
2009 Dodge Journey
Old 06-13-2011, 10:29 PM   #4
2gslse
I think it is mostly due to the rotors on the later 12A's had a different shape to the bathtub section the rotors are front and rear and not interchangeable if I remember correctly.
2006 VW TDI commuter
Old 06-14-2011, 08:03 AM   #5
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Could be the different shape as mention, plus the later rotors are lighter as well.
Other factors are the intake/exhaust stock port shapes and maybe plug
placement. Not sure on that last because they roughly look to be at the same
place on the housings.
Old 06-14-2011, 05:27 PM   #6
one320fc
one Apex @ a time
one320fc's Avatar
Damn thats pretty cool! I didnt realize there was that much difference in the 12As If im not mistaken hp stayed the same on the 12As??
2009 Dodge Journey
Old 06-19-2011, 12:27 AM   #7
PercentSevenC
Custom User Title
PercentSevenC's Avatar
Port timing is the same for all U.S. spec '79+ 12As as far as I'm aware, as is plug placement. There were some variations in carbs and intake manifolds over the years. '79 had a points distributor, '80 had an early style electronic dizzy, and '81-85 dizzys are largely the same except for the GSL-SE which had a different advance curve. '83-85 had a lighter rotating assembly and the beehive oil cooler. '79-80 had the "thermal reactor" exhaust manifold and there are some minor casting differences. I don't remember for sure whether the oil pumps changed during the first-gen era (I know Racing Beat's website has some incorrect information regarding oil pumps); ask Jeff20B, he'd know.
Just a quick rundown off the top of my head. If I made a mistake, someone feel free to correct me.
Old 06-19-2011, 09:49 AM   #8
You mean gsl? Gsl-se has a 13b as you know.
Old 06-25-2011, 03:55 PM   #9
PercentSevenC
Custom User Title
No, I mean GSL-SE. They had distributors, too, you know. Only the fuel was controlled by the ECU. Same with the 12AT, except the 12AT distributor had some sort of boost-retard function. I'm not too familiar with them.
Old 06-25-2011, 06:45 PM   #10
Yeah but this thread about 12a's lol so I was just trying to clarify. I figured you knew the gslse had a 13b :-P
Old 06-25-2011, 07:55 PM   #11
j9fd3s
the 12A evolves a bit over the years, sometimes in totally unimportant ways.
74-75 12A's have the big port, intake closes @50 instead of 40, exhaust closes i think @48 instead of 38 degrees. the rotor housings have the big font MAZDA on them. irons are non nitrided and painted black. rotors are MDR like a 13B
76-78 12A. these get the smaller port, which the 12A keeps in the us, until 85. rotor housings are the "mazda automobiles" ones. irons are still non nitrided, and black. rotors become LDR. the 76-78 parts basically superseded to the 79 spec.
79-80 12A. basically the same as the 76-78, except the irons get nitrided. in 1980 they went from 18 to 17 tension bolts.
81-82 12A. new rotor housings for the catalyst exhaust. lighter flywheel, its like 21# instead of 30#.
83-85 12A. the rear iron gets a T heater hose connection for the beehive. the rotors are lighter. oil pump is the bigger one.
crib notes.
front, middle iron, eshaft and stat gears interchange from 76-85. rear iron is either 83-85 or 76-82. rotor housings are 76-80 or 81-85, reactor or cat. rotors are 76-82 (these have a F or R stamp), 83-85 (NF or NR stamp). flywheel is 76-80, 81-82 (same balance but lighter) and 83-85.
this is ONLY for the US, the rest of the world is slightly different after like 79-80. some markets keep the reactor, some markets got bigger ports, etc etc
Old 07-25-2011, 04:53 PM   #12
-xlr8planet-
-xlr8planet-'s Avatar
Great thread
I think I have a set of 83-85 rotors. What flywheel and counterweight do I have to use with those?
Old 07-26-2011, 01:16 PM   #13
j9fd3s
Originally Posted by -xlr8planet- View Post
Great thread
there are 2 different 83-85 rotors.
the non turbo ones are stamped NF for front and NR for rear, right in the combustion recess
the turbo ones are TF and TR.
you need the 83-85 front counterweight, N225 off the top, and the flywheel is an N249/N231 again off the top.
Old 07-26-2011, 01:52 PM   #14
-xlr8planet-
Thanks man
I will take a look at the ones I have
