Old 06-10-2011, 12:05 PM   #1
Piloto
Piloto's Avatar
Piloto is on a distinguished road
Any Good Carb tuners around Chicago?
Anyone know or recommend any good Carburated/Rotary tuners in or around Chicago/NW Indiana region?
Piloto is offline   Reply With Quote
Old 06-10-2011, 12:08 PM   #2
730RWHP12A
what kind of carb do you have? what problems are you having?
rotaryshack.com
Old 06-11-2011, 03:29 PM   #3
Piloto
Piloto's Avatar
I've got a Holley 650 DP on top and just don't like the motor turning over the numerous times it takes to start the car. I want it set just right for the one MAYBE two crank overs on initial start. The other problem is with the secondaries not kicking when giving it open throttle......you get the slight hesitation or bucking effect.
Btw,the motor is Bridgported.
Old 06-10-2011, 07:22 PM   #4
Kentetsu
Kentetsu's Avatar
If you can drive it for a couple of hours, come on up for the race this Sunday. I'm not really an "expert", but I tend to get by okay. So far we've got about 9 rotaries lined up to be there...
http://myautoevents.com/pls/mae/frmE...event_id=11856
Old 06-11-2011, 08:29 PM   #5
Kentetsu
Kentetsu's Avatar
What do you have for ignition? If stock, then a stronger spark would be a step in the right direction.
Old 06-12-2011, 06:22 PM   #6
Piloto
Piloto's Avatar
Not stock......the car has 2 MSD 6A ignition boxes, 2 MSD coils & matching wires.
Old 06-13-2011, 03:03 PM   #7
Kentetsu
Kentetsu's Avatar
Hmm, then I guess you're back to looking at the carb, or maybe ignition timing, or compression...
Old 06-14-2011, 08:31 AM   #8
Piloto
Piloto's Avatar
Yeah...I'm thinking a combo of timing & carb jetting will sort out the bug.
Old 06-27-2011, 10:45 PM   #9
surem
surem is on a distinguished road
R u running a stock motor or rebuilt motor? The reason why i ask is because if it a rebuilt motor and u use after market apex seal spring that can cause what u are describing when ur trying to start. I have a great carb tuner he's coming in to Chicago at the end of July maybe he can check it out for u.
surem is offline   Reply With Quote
Old 06-28-2011, 09:18 AM   #10
Kentetsu
Kentetsu's Avatar
Got another great race this weekend, July 2nd/3rd... Plenty of help for you up here.
