Old 06-09-2011, 03:46 PM   #1
JustJeff
JustJeff's Avatar
Machine Shop ruined stat gear bearings
I just picked up S5 stationary gears from a machine shop. I had new bearings pressed in them....I believe they ruined them. I'll get some pics up as soon as I can. The rear is particularly bad. One real "nice" scar. The hole for oil passage is off centered. The press in tab is also of course off center and when they pressed that in they did a little damage to the gear.
The front isn't nearly as bad..but it's still not pretty.
I'll get pics up ASAP
Originally Posted by yzf-r1
Old 06-10-2011, 01:50 AM   #2
EasyE1
EasyE1's Avatar
EasyE1 is on a distinguished road
Make them replace them.
EasyE1 is offline   Reply With Quote
Old 06-10-2011, 08:20 AM   #3
What did EasyE1 respond with? I'm so distracted by the avatar I missed it...
Seriously though, tell them to fix it or pay for the replacement.
Old 06-10-2011, 11:17 AM   #4
JustJeff
JustJeff's Avatar
Here are the pics. The ones I took pics of I can feel with my finger
Front Gear
Rear Gear
Oil passage is off-center
Off-center and more scrapes
They nicked the gear trying to press in the off-center tab
Old 06-10-2011, 12:58 PM   #5
Damn that sucks, I hope the own up to the mistakes and do what it takes to make it right.
Old 06-10-2011, 10:26 PM   #6
JustJeff
JustJeff's Avatar
^ thanks, I called the owner as soon as I got home and looked them over in better lighting. He claims that there is no way their press could have damaged the bearings because they used aluminum...which couldn't have damaged the bearing...???
I've been too busy with work to take them back in and show him. We've agreed that I'll be back in on Monday with the parts to show him.
What has me annoyed is that it took them 3 weeks to do that kind of work.
Old 06-11-2011, 03:49 AM   #7
EasyE1
EasyE1's Avatar
3 weeks!? Fail.
The rear bearing is unacceptable period. The front I can't tell how deep the scratches are. But there should be no marking on the bearing surface if the proper tooling was used.
Old 06-11-2011, 05:47 AM   #8
Is this a reputable shop???
This guy is an idiot.
(Journal) bearing material is usually some soft metal like lead, antimony, etc.
http://en.wikipedia.org/wiki/Babbitt_(metal)
Although aluminum's harness is very close to (pure) lead and (pure) antimony, enough abuse will cause damage.
On top of that, you can work harden aluminum to the point where it can get harder than the bearing babbitt surface - any competent person who does metal machining should KNOW this.
http://www.tedpella.com/company_html/hardness.htm
Damage to a journal bearing surface is DEATH.
I bet the aluminum guide / bearing press had sharp edges or the person doing the work was hamfisted or drunk.
Old 06-11-2011, 07:41 AM   #9
Having done this numerous times, I find it very hard to understand how they messed it up. it literally takes about 15 minutes to replace stationary gear bearings and requires very little effort (using pineapple racing bearing installation tool).
You should always clean the tool and bearing and install assembly lube on the surfaces before pressing the bearing in.
I am saddened by this.
Getting the tab mis-aligned is not such a big deal (press it out, turn it and press it back in - although obviously you should catch this before it is pressed all the way in), but the scratches are hard to repair.
Best of luck to you.
Old 06-11-2011, 10:56 PM   #10
JustJeff
JustJeff's Avatar
Originally Posted by EasyE1 View Post
3 weeks!? Fail.
I dropped the parts off and he said no problem, I can pick them up in the AM. I actually forgot about the parts for a week and a half. I stopped in thinking they'd be done. They were still in his office where we left them. He was off property so I called the next day. He said he'd have them the next day. I call next day, they are not done and he is off property. I call a few days later still not done. I give them a week and still not done but he says I can pick them up in the morning.
They had to machine their own tool for the job.
Unfortunately I'm running out of machine shops in my town. I was using a machine shop specializing in automotive work. Till that guy convinced me that putting an electric fan temp switch in the radiator would be equally effective as putting it in the water pump housing.
A quality shop turned down the bearing work because they don't do automotive work.
So I went to this shop. The owner/manager seems shady. Not only did he keep promising me next day completion. But I believe he knows his shop did some poor work. When I picked up the gears in his office and started looking them over he got this look of dread...like he didn't really want me looking them over.
When I called him a few minutes later he started rattling off about using aluminum, etc etc. And I kept responding "Well I"m holding the gears in my hand looking at scratches in the bearings.."
About the tool they used...yes they made a guide/press for it and I was thinking the same thing. I bet they did the rear one first and realized afterwards they needed to clean it better.
Depending on what the owner/manager says on monday, I may be looking for someone to do this work. I've run out of shops in my small town. If I decided to mail them off to someone would you do the work and how much would you want?
Old 06-12-2011, 12:12 AM   #11
What was the problem with the first machine shop? You're telling me you stopped doing business with someone decent just because of a little disagreement on where to put a temp probe?
Come on now, I don't get it.
Tell that one guy to get fucked. He did a piss poor job and if he has any sense of being a good businessman, he needs to fix that crap.
Old 06-12-2011, 02:36 PM   #12
JustJeff
JustJeff's Avatar
I may go back to the first shop, though I get tired of them treating rotary parts like they might explode in their hands at any moment. My plan is to get the first shop to buy me new bearings and refund my labor costs. While waiting for the bearings to show up I'll take the gears to "the first shop", show them the damage done and ask if they can do it without damaging.
Old 06-13-2011, 05:24 PM   #13
JustJeff
JustJeff's Avatar
Did not get to Tristate today, I had to stay at work longer than expected and they close at 4.
Old 06-13-2011, 09:27 PM   #14
Ender
rotors excite me
Ender's Avatar
the machinist I had do my rotor bearings managed to do a great job with a piece of a fucking DRIVE SHAFT for his press tool. there is no excuse for this.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 06-14-2011, 03:44 PM   #15
JustJeff
JustJeff's Avatar
Tristate Machining is replacing the bearings...though he still claims that he sees no issues with the bearings and he'd use them. "But if you're not happy with it we'll make it better"...as he said.
