Old 05-11-2011, 02:21 PM   #1
neit_jnf
Boricua!
Pics of my new Turbo!! 1.15 P-trim GTX35 :D
Custom made for me by Turblown!!
Old 05-11-2011, 02:25 PM   #2
neit_jnf
Boricua!
Check out the nice machining work on the custom back plate!
compared to normal GTX3582R - I don't have housings for it though and it's FS if anyone wants it!
note the center sections size difference and the p-trim has a taller turbine spacer
also note the difference in the turbine impellers, the p-trim is shorter front to back but has a larger diameter and the exducer is flat while the gtx35 has an angle to it...
an yes, I somehow balanced them like that for the pic.
sorry for the crappy quality, all I have is a celphone camera!
Old 05-11-2011, 02:26 PM   #3
neit_jnf
Boricua!
It's basically what is known as a GT3574 or TD61 but with the new GTX billet wheel.
It will be installed using a divided manifold with dual dumped gates and 3 1/2" DP and exhaust. Ported Xcessive LIM, Ported S8 UIM, 850/2000 injectors.
PFC, HKS TP, pre-turbo water injection, etc. ON STOCK PORTS
Old 05-11-2011, 02:45 PM   #4
RXtacy
RXtacy's Avatar
Interested to see the results of this.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 05-11-2011, 04:50 PM   #5
Libor
Libor is on a distinguished road
This is probably best what one can imagine.
Response of 61mm wheel, flow higher than conventional 67mm wheel and hotside that can use that flow on rotary application.
Anxious to see the results!
Libor is offline   Reply With Quote
Old 05-19-2011, 08:11 PM   #6
prrex4ever
prrex4ever's Avatar
Very nice, looking forward to the results also.
Old 05-19-2011, 09:32 PM   #7
neit_jnf
Boricua!
Im waiting on the rest of the kit: xcesssive lower intake manifold, ported and ceramic coated; turbo mani, DP and lines; need to build my fuel system and other details...
Old 06-02-2011, 04:12 PM   #8
RX7 RAGE
RX7 RAGE is on a distinguished road
Are you still waiting to get the rest of the pieces?
RX7 RAGE is offline   Reply With Quote
Old 06-02-2011, 04:44 PM   #9
neit_jnf
Boricua!
yep, still waiting! the xcessive manifold is been ported by one shop, the turbo kit being built by another, fuel system and all the related install work will be done by myself so it'll take a while...
Old 06-15-2011, 01:08 AM   #10
dvo
dvo's Avatar
dvo is on a distinguished road
can't wait to see the way everything turns out!
dvo is offline   Reply With Quote
