Old 04-01-2008, 09:50 AM   #1
impulsive-RX7
impulsive-RX7's Avatar
impulsive-RX7 is on a distinguished road
Can I put a S5 fan clutch on my 12a?
The fan clutch on my 12A is bad. I just acquired a S5 NA engine core. Is there some way for me to use the S5 fan/clutch assembly on my 12a?
I know the bolt pattern is different. I know it's easy enough to buy a used 12A fan clutch off the forum, but I would like to just work with what I have without having to worry about shipping and buying more parts. Will the water pump from the S5 bolt to the 12A? Or can I swap the pulley?
impulsive-RX7 is offline   Reply With Quote
Old 04-01-2008, 07:25 PM   #2
Water pumps have different part #s, and my general assumption would be they are different and wont swap out.
You can always go to the junk yard and find a good cheap electric fan from a taurus and go w/ that...
Old 04-01-2008, 08:26 PM   #3
impulsive-RX7
Ehhh, I've had a bad experience with the taurus fan when I had my TII. I'll stick the reliable old clutch fan.
After I did some digging through the other forums, seems that the S5 water pump housing will fit, but not without modifications. Probably more effort than I'm willing to put into it.
