Old 05-03-2011, 09:39 PM   #1
tweiss3
Mazda Lover
tweiss3's Avatar
need s5 na driveshaft now
Best place to get one cheap and now
Just let go on me on the highway, im waiting for a tow currently.
Snapped the front ujoint, mangled pretty bad on both sides, im gona say not repairable.
Old 05-04-2011, 11:31 AM   #2
Boosted FC
Rotary & Boost Addict
Boosted FC's Avatar
Boosted FC is on a distinguished road
Check in the For Sale section see if anyone is parting out. If not, hit up Kevin Landers.
'05 Copper 6s, '87 TII RX7...248whp & 224wtq @ 12lbs
Boosted FC is offline   Reply With Quote
Old 05-04-2011, 12:11 PM   #3
tweiss3
Mazda Lover
tweiss3's Avatar
Thanks sheldon
Old 05-06-2011, 05:34 AM   #4
tweiss3
Mazda Lover
tweiss3's Avatar
Ok, so anyone know about how much the NA transmission weighs?
Old 05-06-2011, 07:24 AM   #5
tweiss3
Mazda Lover
tweiss3's Avatar
NVM, 78lbs. That will be fun to drop myself saturday on jackstands
Old 05-06-2011, 12:30 PM   #6
Boosted FC
Boosted FC's Avatar
lol.....NA manual Trans is light as fuck. Stop being a bitch Tom. Installed one by myself when I did the Auto to Manual swap on my old FC.
Old 05-06-2011, 12:32 PM   #7
tweiss3
Mazda Lover
tweiss3's Avatar
Well, I will be pulling it myself. I just looked at the FSM, it should be pretty easy. Starter, neutral switch, reverse switch, speedo cable, 6-8 bolts, then the cross member, then drop it slowly
Old 05-06-2011, 02:30 PM   #8
Boosted FC
Boosted FC's Avatar
Put some good fluid in there. You should also change the fr & rr trans seals while you have it out & check on the shifter bushings.
Old 05-06-2011, 02:41 PM   #9
tweiss3
Mazda Lover
tweiss3's Avatar
Well, the shifter has been bashed to inoperability from the snapped driveshaft I found. Thats why the trans is coming out. I may just be getting a junk yard trans from the same place i got the driveshaft.
As for good fluid, I plan on running the schaffers
Old 05-07-2011, 12:22 PM   #10
Boosted FC
Boosted FC's Avatar
Oh.....check the mounts too. Might as well replace them while you have the trans out.
Old 05-07-2011, 10:48 PM   #11
tweiss3
Mazda Lover
tweiss3's Avatar
Mounts look like new. But here is what the driveshaft did:
What are my options here?
Old 05-08-2011, 01:39 AM   #12
Check to see if the linkage(s) are not bent.
If they are okay, you can get away with just replacing the tail shaft housing.
Dead non-turbo FC transmissions should be plentiful?
Old 05-08-2011, 07:39 AM   #13
I have a tail housing that you can have for paying shipping. Let me know as I have to take it off the transmission.
Old 05-08-2011, 06:14 PM   #14
tweiss3
Mazda Lover
tweiss3's Avatar
And it has the shifter housing on it? Im in, pm me where and how much.
Old 05-09-2011, 07:18 AM   #15
tweiss3
Mazda Lover
tweiss3's Avatar
A touch better angle
