Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Prosport Gauges
Prosport Gauges www.prosportgauges.com (FL) Offering affordable performance gauges with the hottest design & exceptional quality
Old 04-26-2011, 06:41 PM   #1
RotaryXperiment
prosport sender in factory location?
can it will in the rear iron on a s5 iron? and how accurate is it there
Old 04-26-2011, 07:02 PM   #2
Old 04-26-2011, 07:06 PM   #3
RotaryXperiment
can it fit fit in rear iron (stock sender location)
Old 04-26-2011, 07:11 PM   #4
RotaryXperiment
looks like factory is a 1/8 BPS and sender 1/8 NPT
Old 04-26-2011, 07:23 PM   #5
infernosg
IT'S ALIVE!
infernosg's Avatar
Yep, Mazda likes to use 1/8" BSPT for their oil pressure senders. It IS NOT the same as 1/8" NPT but adapters are easy to find (McMaster). As far as accuracy goes I'd assume it's accurate enough for whatever use you have in mind considering it is the location Mazda decided to put their unit.
Old 04-26-2011, 07:29 PM   #6
RotaryXperiment
o btw i meant for coolant temp
sometimes i type and think my thoughts are coming out onto words on the keyboard lol
Old 04-26-2011, 11:54 PM   #7
JustJeff
JustJeff's Avatar
Yes coolant temp sender will thread in the S5 rear iron spot
Originally Posted by yzf-r1
Old 04-27-2011, 06:14 AM   #8
RotaryXperiment
arent they different threads though?
Old 04-27-2011, 07:51 AM   #9
YES - the Prosport sender is 1/8"NPT, the hole Mazda threaded into the rear iron is 1/8"BSPT - you will STRIP the threads if you try screwing the Prosport sender directly in there. Buy the adapter.
Old 04-27-2011, 09:56 AM   #10
RotaryXperiment
u can fit their sender o their 1/8 bsp adapter. sender is too long and that adapter might effect reading.
im using and adapter now on the back of wp housing right under ecu thermosensor and the reading can be as far as 20* off, comparing haltech temp reading to prosport gauge
Old 04-27-2011, 10:03 AM   #11
JustJeff
JustJeff's Avatar
We are talking about the rear iron water temp location correct? Unless I'm remembering incorrectly I have taken my Prosport temp sender and screwed it into the rear iron water temp location. It screws all the way down without ever catching. My engine is in pieces, next time I'm messing with parts I'll do it again to make sure.
Old 04-27-2011, 10:32 AM   #12
RotaryXperiment
ya i was asking about factory temp sender location in rear iron.
Old 04-27-2011, 11:06 AM   #13
JustJeff
JustJeff's Avatar
^I may need to leave work early today. If that happens I'll check again, but from memory my Prosport threaded onto my S5 rear iron without ever catching or tearing up threads.
Old 04-27-2011, 11:26 AM   #14
RotaryXperiment
ya if u can check for me that would be great!
Old 04-27-2011, 04:00 PM   #15
RotaryXperiment
and how accurate was it there? my current spot on wp housing and adapter is 15-20* off
