Old 03-31-2008, 08:05 PM   #1
eyecandy
eyecandy is on a distinguished road
Blitz boost controller and a bunch of engine parts
Pics can be found here http://s240.photobucket.com/albums/f...rts/?start=all
ENGINE:
Blitz DSBC Spec R (new never used) $290
Billet oil filter pedestals w/npt ports and hardware $65 each
JDM Vac block $60
3" V-band clamps $50 each
Primary Fuel rail w/injectors $60
Secondary Fuel rail w/injectors $70 (or both rails w/injectors for $110)
MOP $50
MOP oem lines $10 (or free with MOP)
Motor mounts w/good bushings (aluminum/steel) $100
Iron Set (front, intermediate, rear) $290 for the set or 110 ea
E-Shafts $60
Rear stationary gear $35
Oil pump w/chain $35 ea
Tension bolts $15 ea set
Tubular dowel rods $10 ea set
Water pump w/housing $70
Front counter weight $20 ea
Metering oil pump gear $10 ea
Oil pan pick up $10 ea
Oil pan $30 ea
Main pulley (oem) $10
Flywheel (oem, needs resurfaced) $20 ea
DRIVETRAIN:
Super*Now transmission cooling plate $220
BOOKS/MAGS: $15 each
RX7 magazines vol 7, 9
Let me know if you have any questions, I accept paypal. You can pm or email me at seeltuned@aol.com
The only thing off the top of my head I am looking for is a set of interior trim pieces. Condition does not matter just as long as they are not broken.
eyecandy is offline   Reply With Quote
