Old 04-15-2011, 12:52 PM   #1
FC~2BIT
FC~2BIT is on a distinguished road
Exclamation My FC stopped running~PLEASE HELP
I just bought an 87 RX7 N/A last night, was running fine till about half way home. Then it just started losing power and wont rev past 4,000. What could be causing the problem?
This morning I turned the car on and let it idle for a minute then drove it around the block. It was idling at about 1,200 and ran just fine this time with plenty of power
I went out a second time today and the car wouldnt start.
what could possibly be causing any of these problems?
Thanks
FC~2BIT is offline   Reply With Quote
Old 04-15-2011, 01:05 PM   #2
No CEL?
Fuel pump (or fuel related issue) is a good start.
Are you out of gas?
Old 04-15-2011, 09:26 PM   #3
Ender
rotors excite me
Ender's Avatar
electrical system is a good place to start, too. poor grounds in different places can cause each of the individual problems you described.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 04-17-2011, 11:21 AM   #4
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
I would recommend a compression check, then a tune up (plugs, wires, fuel filter, air filter, etc.), if no change you might want to check out the fuel pump, tps sensor, maf sensor, etc.
Did you happen to run over something before the trouble began?
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
DO NOT TRY THIS AT HOME!!!
