Old 03-28-2011, 11:41 AM   #1
aaronoverholser
In search of knowledge.
aaronoverholser is on a distinguished road
Broken solenoid, please identify.
I have a plastic nipple broken on this solenoid on my 86 GXL. In the picture with my hand in it where my index finger is is where the missing connection goes. Can someone teach me what the purpose is and direct me into how to find a replacement? If anyone has one I would be interested in it.
Thanks!
Zoom Zoom- The only car on the road that is truly something different... the RX7!
aaronoverholser is offline   Reply With Quote
Old 03-28-2011, 12:13 PM   #2
mazdamikes
mazdamikes is on a distinguished road
Its is a solenoid valve and it is part of the all the emission stuff on your 7. If you need one I can get you one. It is at my sons garage in Fort Wayne, IN.
mazdamikes is offline   Reply With Quote
Old 03-28-2011, 12:31 PM   #3
aaronoverholser
Emissions, can I delete it? I have the instructions from rotary resurrection on how to do the emissions delete on this car, I wonder if that would get rid of it...
Old 03-28-2011, 12:46 PM   #4
FRED
It depends on what the color dot is on the solenoid and or what the color of the electrical plug is as to what it was used for.
All solenoids on that rack are the same item just some configured differently.
So? Was the elect plug Blue, Grey, White, Orange or what???
Old 03-28-2011, 12:54 PM   #5
aaronoverholser
It was the blue electrical plug, the solenoids themselves all look the same, but your implying that maybe different colored plugs do different things.
Old 03-28-2011, 01:25 PM   #6
FRED
The Blue plug is for the RELIEF solenoid and partly controls the ACV functions. Remove the plug from the Relief solenoid and the ACV dumps the airpump air into the fender instead of thur the ACV to the exhaust.
The FILTER on the solenoids can be pulled off by hand and put on any of the three plastic nipples on said solenoid.
As an example the grey or Switching solenoid is configured differently. IT's filter is on a nipple other than the nipple on the Blue (relief) solenoid.
Switching solenoid (grey) also controls part of the ACV functions.
Orange solenoid is for the FPR.
Yellow solenoid is for the EGR.
Yes they all do different things in life.
Personally I'd swap the broken Relief solenoid with the Yellow EGR solenoid. Those two are configured the same. They have different colored DOTS on the solenoids so now you will have the Blue plug going to the solenoid with a Yellow dot etc. DON'T just swap elect plugs. Swap the two solenoids. Get it???? If not say so.
About the EGR.............just cap or plug off the vacuum line that goes from that solenoid to the EGR itself and maybe plug the other vac line that went to it also. All RX can pass emisison without a EGR valve in place. Question?
Old 03-28-2011, 01:29 PM   #7
FRED
Carefully stare at the Blue or the Yellow solenoids and where the filter is on those. NOW look at either the Grey or the Orange solenoids and you'll see the FILTER is on the inbd end of the grey and orange and is on the outboard end of the blue and yellow solenoids.
All the solenoids are the same item. Its where the filter is located on the solenoid that makes them different and act differently.
Old 03-28-2011, 01:33 PM   #8
mazdamikes
Yes, you can remove it just follow Rotary resurrections instructions.
Old 03-28-2011, 01:35 PM   #9
mazdamikes
Do you need blockoff plates? I have complete sets with Stainless hardware for $25 plus shipping
Old 03-28-2011, 03:44 PM   #10
aaronoverholser
I have EGR and ACV blockoff plates from Racing Beat. I have my instructions from rotary ressurection, and I am probably going to have a few question while doing it!
So I take it some of you have followed those instructions with good outcome?
Old 03-28-2011, 04:39 PM   #11
I had Kevin (Rotary Resurrection) remove my emissions, which I assume is the same as his instructions. Everything works fine, except he took off the BAC valve. I'm not sure what the instructions say but there is no reason to take it off. As for everything else, I have no emissions and those solenoids are just sitting in my bay useless.
Old 03-28-2011, 05:35 PM   #12
mazdamikes
The instructions are good
