Old 03-15-2011, 01:09 AM   #1
IH8DSM
IH8DSM's Avatar
1 msd 6a + 2 ls1 or 2 coils need opinons
I need better spark i tried the 2gen direct fire but it didn't last long. Is anyone running a single msd 6a and ls coils?
Just trying to find a good direct fire set up that will be reliable and handle my holley 600 cause right now my single blaster coil just isn't cutting it
Old 03-15-2011, 02:31 AM   #2
FC Zach
FC Zach's Avatar
MSD 6A and 2 Jacobs Electronics Ultra-Coils
$86.61 at Amazon http://www.amazon.com/Jacobs-380876-.../dp/B000BWE1PC
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 03-15-2011, 02:43 AM   #3
FC Zach
FC Zach's Avatar
I chose these mainly for the cycling ability
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-15-2011, 09:32 AM   #4
I'm going direct fire with mercury quicksilver coils. Supposedly extremely strong when TTT did coil testing, don't know if they'd work for your specific application, but might want to consider them if you haven't yet.
Old 03-15-2011, 10:19 AM   #5
IH8DSM
IH8DSM's Avatar
I've heard about the Jacobs and the mercurys. I'll prolly just end up doing the Jacobs since me and zach have similar set ups. I'll look into the mercurys some as well.
Just seen a few build using ls1/2 coils and wasn't sure if they were as good as the aftermarket.
Old 03-15-2011, 11:22 AM   #6
LS1 coils suck. Fuck those things. They wet fouled on a rebuilt after 15 minutes of runtime. LS1 coils suck. LS2, from the research I did on the LS1 forums, V8 lamo's are picking up 15hp swapping to LS2 coils. And I found one guy who strapped his truck down, ran it with the LS1 coils, and then without taking the truck off the dyno swapped the LS2 coils in and picked up something like 15rwhp. So there might be something in the LS2 coils, I just haven't had the opportunity to test them back to back like I would prefer to.
Vex is rightm the Quicksilver coils are STOUT units, without a dount, good coils. but big, and they have an internal ignitor and some other internal electrical trickery as well. I still owe C Ludwig a phone call
Old 03-15-2011, 10:01 PM   #7
IH8DSM
IH8DSM's Avatar
What kind of eletrical trickery ? Like guttin a ignitor or more then that, I'm not the biggest electrical fan so what would be the simpler option
Old 03-15-2011, 11:15 PM   #8
FC Zach
FC Zach's Avatar
If this helps, here you go.
http://www.hrpworld.com/client_image...ader/766_1.pdf
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-17-2011, 08:47 AM   #9
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
I'm running HEIs as ignitors and 2 FORD TFI coils and the sparks is excellent.
The HEIs are just standard 4 prong ones (DR100s) and the TFI coils are
from the boneyard off of FORD F150 pickups. Its cheap and its a very good
spark. I dropped trailing altogether. I have a write up on the other forum
with details.
If you need to run higher than 8K I would recommend HO HEI and better after
market TFI coils or maybe these LS2 thingies folks are talking about here.
Old 03-17-2011, 09:22 AM   #10
FC Zach
FC Zach's Avatar
Yeah I like your set-up, I recommend the TFI coils. The coil referenced up top is pretty much the same thing just an aftermarket fancied-up version. In fact those coils actually come with the standard 2-spade style connection now, reason why my 2 older direct fires are screw-on terminals and the newer trailing is what i just mentioned.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
