Old 03-14-2011, 07:44 PM   #1
Waffles
Waffles is on a distinguished road
1 piece apex seal
So I picked up a used engine that I tore down to check all the specs and give it a good cleaning. When I opened it I found that it had 1 piece apex seals. Does the install process differ any from the FSM? Also it appears that each apex seal has only 1 spring, is this normal for a 12a?
Waffles is offline   Reply With Quote
Old 03-21-2011, 12:54 AM   #2
diabolical1
I have radioactive semen
i tend to think the process would be the same.
what you probably have are carbon seals in that engine, and yes, 12As use one spring only.
Old 03-21-2011, 01:30 PM   #3
Waffles
Sounds good. Thanks for the info. Now I just need to waiting on my racing beat gasket kit and intake manifold to show up.
Old 03-22-2011, 08:01 PM   #4
Be careful if those are really carbon seals (do a little research). I think that I recall that you have to glue them down in the rotor and pull start the car as they must initially contact the housing as a high speed to avoid failure (this is what I recall, but I never did it, I heard guys talking about it - 15 years ago).
Old 03-22-2011, 09:08 PM   #5
Waffles
Now you have me worried. Is there any sure way to tell if they are carbon. They feel metallic to me
Old 03-23-2011, 09:57 PM   #6
Here is a carbon apex seal from Mazdatrix
I don't see anything on the internet about the carbon seals requiring special break-in, but Mazdatrix claims only a 20,000 mile life.
Old 03-24-2011, 02:21 AM   #7
diabolical1
... Mazdatrix claims only a 20,000 mile life.
that being said, does anyone have any idea what a typical lifespan was for the older carbon sealed (6mm) engines?
