Old 03-09-2011, 06:18 PM   #1
Tanj!
Tanj!'s Avatar
Tanj! is on a distinguished road
Factory LSD on 86 Sport?
Reading around I seem to be getting contradictory information. Would an 86 Sport have come from the factory with a LSD?
Tanj! is offline   Reply With Quote
Old 03-09-2011, 06:48 PM   #2
Boosted FC
Rotary & Boost Addict
Boosted FC's Avatar
Boosted FC is on a distinguished road
If by saying Sport you mean the SE model with the 4-lug wheels, NO it would not have had a LSD.
'05 Copper 6s, '87 TII RX7...248whp & 224wtq @ 12lbs
Boosted FC is offline   Reply With Quote
Old 03-09-2011, 07:06 PM   #3
An 86 GXL with the Sport package (just aero pieces) might have it.
Old 03-10-2011, 12:17 AM   #4
josh18_2k
there is an S4 sport model, but i think its only 87-88? they're pretty rare.
its basically a base model (no sunroof, cloth interior, manual windows) with GXL drivetrain (LSD, 5 lug, big brakes). i think they also have the rubber spoiler in back.
definately the best starting point for a build.
Old 03-10-2011, 03:23 PM   #5
Tanj!
Tanj!'s Avatar
^ This. Of the three FC's I've owned two of them were 86 Sport models. My understanding was they were an 86/87 thing only. They have the aero package (chin spoiler, spats in front of all four wheels, and the duckbill spoiler). I had (may still have) the original window sticker from my first one that actually said Sport on it. Neither had storage bins either. One had power steering the other didn't.
It's all this confusion about the actual sub-model that has me asking about the LSD. No one seems to have a good answer. Guess I'll just have to crack open one of the diffs.
Old 03-11-2011, 01:06 AM   #6
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
if it has 4 lug, definitely not.
Old 03-11-2011, 02:29 AM   #7
A "Sport" model, by definition, has 5-lug hubs with the 4-piston front brakes and rear vented rotors.
This is the top-tier brake package for any FC, which includes Turbo II's, convertibles, 1988 GTU, 1989 - 1990 GTUs, and GXL models.
Old 03-11-2011, 09:19 AM   #8
In '86 there was a "Sport" model. This is different than the bottom end SE model in later years.
Old 03-29-2011, 10:14 PM   #9
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
I have an 86 sport for my dd, came with all the mudflaps and aero stuff, as far as i can tell nothing says that it has an lsd but it sure leaves 2 marks when i light up the tires leading me to believe its got one. On a side note, when i got the car i noticed the owner before the guy i bought it from had done quite a bit of decent mods including steel braided brake lines and racing beat header bunch of little stuff. So im unsure if it came with an lsd or that dude installed one.
Old 03-29-2011, 10:53 PM   #10
My '86 sport is open diff.
Old 03-29-2011, 10:57 PM   #11
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
Ah, must have been installed by that dude then cool.
Old 03-30-2011, 02:57 AM   #12
FC Zach
FC Zach's Avatar
Yeah I have an 87 Sport, did not come with an LSD although I did install one into it.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 03-31-2011, 10:42 PM   #13
Shainiac
Shainiac's Avatar
Shainiac is on a distinguished road
The GXL was the only S4 NA to have a LSD until the 88GTU. The Sport has an OPEN DIF.
I grenaded the output shaft on my 86Sport and tore the dif down. It IS open. I have the a scan of the original 86 brochure, but the GXL is the only model with a check mark next to LSD.
Shainiac is offline   Reply With Quote
Old 07-04-2011, 11:21 PM   #14
junito1
junito1 is on a distinguished road
I had an red 86 gxl i think. Had the 4 piston calipers with 5 lug.
The rear end had the little tab on the fill nut that said Limited Slip or something.
junito1 is offline   Reply With Quote
Old 07-05-2011, 11:13 PM   #15
Yes, I have a friend who bought an '86 sport brand-new. I assure you that they are not LSD from the factory.
Two black marks does not indicate LSD, my '91 is as open as can be and still lays two marks.
Jack the car up, put the transmission in neutral and turn a rear tire forward, if the other side turns forward, probably an LSD, if it is stationary or turns backward, it is probably open or worn out.
