Old 03-05-2011, 08:09 PM   #1
To_Slow
3mm Wire EDM cut rotors.
Here is some pics/video of some rotors that i wire EDM cut for a custo.
Uploaded with ImageShack.us
Video...
http://www.youtube.com/watch?v=fP0xpjf2ziw
Electrical Discharge Machining (commonly known as "EDM Machining") makes it possible to work with metals for which traditional machining techniques are ineffective. EDM machining equipment makes it is possible to cut small odd-shaped angles in hardened steel. The EDM machining process was developed by the aerospace and electronics industries to provide tolerances accurate to one ten thousandths of an inch. The accuracy of EDM makes it ideal for machining the 3mm opening to accommodate thicker apex seals. The resulting surface finish is ideal for use with any apex seal material and recommended for use carbon or ceramic apex seals.
My link
Old 03-05-2011, 08:50 PM   #2
Redshft
Redshft's Avatar
Redshft is on a distinguished road
Very cool. Thanks for posting that. I had my RX8 rotors EDM cut to accept the deeper RX7 apex seals (didn't make them any wider) but I didn't see it being done, so I was curious what the process looked like.
2004 RX8 GT
1986 RX7 Track Car: 13B Bridge Port w/ Renesis Internals and Weber Carb
2003 MazdaSpeed Protege
1988 RX7 Convertible - new project
2004 Impreza and 2003 Legacy wagons for hauling groceries and The Dog
Redshft is offline   Reply With Quote
Old 03-05-2011, 09:07 PM   #3
Good ol' EDM. How long does it usually take for the EDM to take off enough material? When I was doing the EDM lab we estimated that the quickest one (which didn't leave a great surface) took upwards of 1 min for not a whole lot of material removal, and it only went slower when it was set for a good surface finish.
Old 03-05-2011, 09:19 PM   #4
To_Slow
To get the best surface finish takes about 30 min per slot...
Thanks
My link
Old 03-06-2011, 02:59 AM   #5
That's very time expensive, but it's not surprising for what it does.
