Old 02-28-2011, 08:35 AM   #1
Oem Electrical Connectors
Anyone have any sources for a place that sells OEM style electrical connectors? For instance: Crimp pieces for BAC, TPS, Water Temp, etc.
Old 02-28-2011, 09:15 AM   #2
Eastern Beaver may.
Old 02-28-2011, 10:26 AM   #3
I tried hunting through their website, but I'm not seeing any of the one's I'm looking for (might have found the TPS). Is there someplace specific on there you are thinking of?
Old 02-28-2011, 12:59 PM   #4
No, I haven't looked through the page much. It was just referenced for me by a couple people. I plan on either using Metripacks or cutting off the stock connectors and butt connecting them to the wiring.
Old 02-28-2011, 01:37 PM   #5
88turboii
destroy, rebuild, repeat
88turboii's Avatar
i dont have any part numbers, but you could try poking around these:
http://www.mouser.com/Interconnects/...ors/_/N-1ehb5/
http://www.alliedelec.com/connectors/
btw, does anybody have a part number or source for stock ecu connectors?
Old 02-28-2011, 11:04 PM   #6
rx7 FC TII
rx7 FC TII's Avatar
rx7 FC TII is on a distinguished road
try blackdragonauto.com
they might have the connectors.
Today, my girlfriend was about to give me a blowjob. When her lips met my penis, there was a huge static shock. I never got the blowjob, she is still laughing and I have ice on my penis. FML
rx7 FC TII is offline   Reply With Quote
Old 02-28-2011, 11:06 PM   #7
looks like they don't have FC parts anymore:
http://www.blackdragonauto.com/carcatalog.htm
Old 03-01-2011, 02:41 AM   #8
Howru
Louvers!
Howru is on a distinguished road
I got a set at Vintage Connections. The 4 and 6 pin connectors work, but on the 2-pin and 3-pin T connectors the retaining tang on the pin is positioned differently. They work, but need a bit of force to get them locked together.
88 GXL N/A -- Maybe I should've kept the exhaust diffusers...
Howru is offline   Reply With Quote
Old 03-01-2011, 09:22 AM   #9
The only one you REALLY need is the BAC there T. The others are the same as some aftermkt Bosch units. The BAC connector is the only one that I raped from a factory harness and butt connected to the harness. Not happy about it but whatever. The other sensors you should be swapping out anyway.
The other option is to get some small Fast-on terminals, drop a bit of solder on the pins, and then fill the void with epoxy and add a 2-pin deutsch or metripak connector.
Old 03-01-2011, 09:57 AM   #10
More work than I'm willing to do. As it currently stands TTT; I'm having to retain my craptacular intake manifold (no new goodness for me), which means my TPS and BAC valve are being kept until I have the funds, time, and means to build the new intake manifold with the LS TB.
The water temp sensor I thought I could keep stock and be okay with? I'll be re-doing a lot of sensors including a Fuel Pressure sensor (I know you like it), air temperature sensor, new oil pressure sensor, and a 3 bar GM sensor so I can grow with the boost (I'm also picking up a boost control solenoid).
As others have mentioned, my biggest concern is sourcing a BAC connector, mine has seen better days.
Old 03-01-2011, 10:13 AM   #11
What's more work? soldering and epoxing in a few wires?
You should be able to find a connector kit for the TPS... call Motec?
You might be able to keep the stock coolant temp sensor, but why? They can be had with a connector kit for $38?
I was never able to find a replacement socket and terminals for the BAC. Only option is either the teminal/epoxy route or rape a connector from a different harness.
Old 03-01-2011, 10:26 AM   #12
Epoxying yes. Soldering not so much. I think I might honestly just clip my BAC connector from my factory harness, solder it on the Haltech harness (I know, I know, but I'm planning on replacing the BAC eventually anyways so I'd just be wasting a crimp if I did it that way--in fact I may do that for a majority of the sensors I have to use).
Would have to be rather inexpensive as I'm already planning on trashing it once the above criteria is met.
Maybe when I upgrade the intake manifold I'll spend the extra $38 bucks. It just seems kind of pointless right now.
That sucks. Not even Motec sells 'em?
Old 03-01-2011, 02:11 PM   #13
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
eastern beaver only really has old style connectors like the ACV connectors and many found on 1st gens.
these connectors will work for 86-88 injectors(88 high impedence injectors you have to cut the locating lug off of the injector as well as the water thermosensor lug to make them fit properly):
airtex - 1p1000
GP sorenson - 800-9213
BWD(Borg Warner) - 27427
for the BAC valve you can use an S5 injector style clips found here:
http://kgparts.com/index.php?page=kgfuel
ND-IC, 3/4 down the page
for double sided connectors like the two 2 pin ACV connectors, it's easier just to go the the wrecking yards and pick up 2 and 3 pin connectors and cut off both sides and replace the whole thing(doesn't matter what connector you use or what car you got it from but i personally prefer the metri-pak connectors found on later model GM vehicles which are also readily available at connector stores).
and for reference, i have found that supra's of the same year range use many of the same tyco connectors as the later model RX7 such as S5 and S6 use. unfortunately they usually aren't in much better shape but they are easier to find in wrecking yards.
problem with the stock connectors is that many manufacturers require rediculously large orders who actually do have OEM connectors still for these harnesses.
i have spent a bit of time researching the connectors but with little success, you can also find some good info for later models RX7s in my thread here:
http://www.rx7club.com/showthread.ph...ock+connectors
Old 03-02-2011, 01:01 AM   #14
JustJeff
JustJeff's Avatar
I'm rebuilding my harness. I was thinking ahead and snipped the water thermo plug (Green rectangular two pin one on the back of the water pump) from a junkyard. That plug is in awesome shape.
My CAS plug is horrible. But I believe I can buy the male terminal pins locally.
Probably going to rebuild my TPS. IIRC the actual male/female plugs are good. But being a N/A harness converted for a turbo swap, the wires were extended and while it's out I want to make sure the patch is in good shape.
Old 03-02-2011, 07:42 AM   #15
If you're not running the factory ECU, just replace the coolant sensor and get a Bosch termination kit.
TPS, same thing. I was able to find a Bosch (I think) connector that plugged right in, NEW pins.
CAS, get a deutsch connector and be done with it.
