Old 02-17-2011, 01:56 AM   #1
anodizing or painting timing wheel
I'm thinking about either painting or anodizing (I'd rather anodize actually) the wheel that the CAS reads off of but I want to make sure it won't have any adverse effects on timing or anything. I'm not sure how they are coated from the factory but I'm sure there is something on there since they are green. Does anyone have any idea if painting or anodizing it would hurt anything? I figure anodizing would be less of an issue since you're essentially just staining the metal instead of covering it with paint, since it reads with magnetism. But I could be wrong on all this haha.
Old 02-17-2011, 07:17 AM   #2
Signal 2
Viable Fossil
Signal 2's Avatar
I painted my trigger wheel a few years ago and noticed no ill-effects. It's magnetic, so after sanding off the OEM coating I went very light around the tabs. I've seen no ill effects. I would think anodizing would have even less effect than the OEM coating.
Jim
VR R1 FD
Old 02-17-2011, 08:55 AM   #3
Cool. That's what I figured but I just wanted to check. I figured if anything I'd just sand off the back of the tab completely. Thanks!
Old 02-17-2011, 09:51 AM   #4
Anodize / anodizing implies aluminum.
I don't think that wheel is made out of aluminum?
It's most likely plated (i.e. "cad plated") or coated.
Old 02-17-2011, 11:06 AM   #5
Signal 2
Viable Fossil
Signal 2's Avatar
Your right, forgot that. The OP won't be able to anodize the steel trigger wheel.
Jim
VR R1 FD
Old 02-17-2011, 02:59 PM   #6
Damn haha. I didn't know you could only anodize aluminum. Thanks for clearing that up. I wonder if I could get it re-plated then.
Old 02-17-2011, 05:05 PM   #7
Signal 2
Viable Fossil
Signal 2's Avatar
If you REALLY want to make it shine I guess chrome would be an option.
Jim
VR R1 FD
Old 02-19-2011, 04:11 AM   #8
I don't want to make it shine though, I'm trying to turn everything black. I've even thought about sandblasting my aftermarket pulleys and anodizing them. I believe they're aluminum anyway haha.
Thanks for the input guys. I guess I'll look into plating for the non-aluminum stuff then.
Old 02-19-2011, 09:45 AM   #9
Garfinkles Motor Works
Mine is power coated and I sanded the back side of the tabs alittle to be sure the siginal was not weak . That was 6-7 years ago .
Old 02-19-2011, 09:54 AM   #10
Old 02-19-2011, 10:33 PM   #11
OK, maybe I'll do that too. Thanks!
What is that look for? LOL I've wanted to do this for several years, I just finally got the opportunity and money at the same time to do it haha.
Old 02-19-2011, 11:15 PM   #12
Prodigy
Half bubble off plumb
Prodigy's Avatar
I think it would look good, I hate how my pullies all look a nice neutral weathered color, then my greddy pullies are anodized light blue, looks so tacky... But I'll care about theta more once it's running good, take care of ascetics later... First I want more power, and a good tune to go with it... BDC anyone....?
Lol
J.
360 gamertag: Tichlis
Old 02-19-2011, 11:22 PM   #13
^Yeah that's where I am now. I have some time during the engine rebuild so I figured I'd go ahead and take care of the color swap while I'm at it.
BDC LOL!!
Old 02-19-2011, 11:30 PM   #14
Lol
J.
Get ahead of the curve, walk to the street, get a few pounds of road salt, remove air filter, rev to 8k, pour sand into engine.
Uh huh,....... couldn't be when I opened the hood you went, wow that really does look good
Old 02-20-2011, 12:02 AM   #15
Prodigy
Prodigy's Avatar
Hey I can do that myself, and it's cheaper!!!!! No need to supply your own datalogit either
J.
