Old 02-10-2011, 12:10 AM   #1
FC Zach
FC Zach's Avatar
Question Eccentric Shaft End Play?
The specifications within my Haynes manual specify that the "Standard" is .04 to .07 mm with a max of .09 mm. I started off with my "K" spacer and had a reading on my dial gauge of .015 (give or take .002 mm). I felt that may have been a little too tight so I borrowed an "X" spacer from jfaplanet and received a reading of .02 mm (maybe .002 mm more). IIRC the "S" and "T" spacers are uncommon and was wondering if the reading I received from the "X" (.02?) was good enough, or is it too tight still? ? ?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
