Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Defined Autoworks
Defined Autoworks Race prep, Dyno tuning, Rotary Performance, Roll Cage Builds, Unique Fabrication and Transplants
Old 02-06-2011, 04:56 PM   #1
GtoRx7
High Horspower Sheet Metal 20b intake manifold
After lots of time on the dyno, we have made a economical way to heavily increase horspower for turbo and n/a 20b's. We require a 20b intake core for the modification. This setup uses a 90mm throttle body. All the port entrances are fully venturied for optimal flow.
Price is $1100.00
DEFINED AUTOWORKS
Where concept meets results
Red 1970 Mazda R-100 with 10a
Black 1974 Mazda Rx4
Old 04-10-2011, 07:47 AM   #2
What are the power gains seen from this?
Old 04-10-2011, 11:21 PM   #3
GtoRx7
10hp n/a and 15-25hp turbo.
DEFINED AUTOWORKS
Old 04-12-2011, 05:07 PM   #4
remydrm
remydrm is on a distinguished road
Have you made any manifolds for FD with 13BREW mated to GZ LIM?
I'd be very interested in that.
remydrm is offline   Reply With Quote
Old 04-12-2011, 11:06 PM   #5
GorillaRE
Outside the "box"......
GorillaRE's Avatar
15-25hp? Do you have a graph of this? At what boost level, power output, rpm and with what turbo? 15-25hp is not a lot in a turbo 20B for $1100 when all you have to do is run 1psi more boost to achieve the same, if not more power...
-J
Old 04-13-2011, 12:22 AM   #6
GtoRx7
No, but we can very easily.
-J
Gaining power by increasing boost is completely different than gaining horsepower by reducing restrictions. As you already know. There will be times when no more boost can be added for a horsepower gain. I admit this intake did not create as much power as we wanted. But it is still a bolt on gain. I dont have a dyno chart on a turbo 20b because this has only been tested on our n/a 20b. 15-25 hp will be at 10-16psi with a proper sized turbo.
DEFINED AUTOWORKS
