Old 01-31-2011, 01:41 PM   #1
tweiss3
Mazda Lover
tweiss3's Avatar
Oil temperature
well, i have a gauge sitting around, so I am going to install it with a sandwich plate at the filter. What is the typical oil temperature at operating temp in this location? All the FSM has is oil pressure, no oil temp.
Old 01-31-2011, 01:48 PM   #2
C. Ludwig
Rotary Masochist
That location is post cooler, so it should be cooler there than if you measure the in the pan. Something in the 190-220 range is usually OK. If you start seeing north of 240 you'll begin to have issues.
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 01-31-2011, 02:46 PM   #3
tweiss3
Mazda Lover
tweiss3's Avatar
So, it should be about 80*C? Good to know. My gauge is metric, which I think is fucking hilarious, along with a metric oil pressure gauge. Gota love canadian parts (weaponx gauges before they quit making them)
Old 01-31-2011, 03:06 PM   #4
I've always wondered why it's generally accepted to pull an oil temp as it goes into the engine. I'm doing it too, but shouldn't we be pulling the temp as it exits the engine, just like the coolant?
Old 01-31-2011, 03:09 PM   #5
tweiss3
Mazda Lover
tweiss3's Avatar
technically, we probably should pull both, or before cooler temps, but that opens a whole new can of worms in dealing with leaks.
Old 01-31-2011, 03:13 PM   #6
Why? There are plenty of adapters out there that can easily do it. Especially if you've got some -10 lines. I wouldn't drill/tap the front cover. If I were to go that route, I would weld an 1/8" npt bung onto it
Old 01-31-2011, 03:40 PM   #7
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
I have mine in the oil pan, no special fittings necessary in my case.
Temps I see so far are 160-170*F.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 01-31-2011, 04:13 PM   #8
http://fc3spro.com/TECH/MODS/EL/GAUGES/otemp.htm
