#1 |
Simply Rotarded
Rep Power: 17 ![]() |
A question about Wipers
I tried replacing my original switch with a "good when removed" switch. The switch that I replaced my original was worse than the orginal. It would not turn off the wipers at all (one speed).
I have replaced all three relays, and it seems to be working correctly (front, rear, intermitten, etc.). When turning the wipers off they do not return to "home". They simply stop. I am not 100% if there is any difference in speed between low and high. Do I need a new wiper motor, or another switch?
LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! Last edited by LunchboxCritter; 01-30-2011 at 07:24 PM. |
#2 |
Rotorhead
Rep Power: 18 ![]() |
You'll need another switch.. At least yours works, mine only works on "I" lol!
Currently running: 90 GTUs converted to S5 TurboII. Track car. 90 N/A GTUs.. Running project car 89 N/A GTUs in Black #2 10/6/18 Blown coolant seal undergoing rebuild and restomod. |
#3 |
Rep Power: 10 ![]() |
New wiper motor. Check the park ciruit. You might be able to clean out the contacts on the park switch. it may come back to life.
#4 |
Simply Rotarded
Okay I think I may try a new motor, and if that doesn't fix it, then I'll source yet another switch.
Sooner or later I'll have a "new" old car. Replacing everything is getting old, as it surely slows down upgrades.
LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! |
#5 |
IT'S ALIVE!
This may sound like a dumb comment but you might have damaged the switch circuitboard. What is happening to you seems similar to what happened to me when I tried to replace the relays in my old switch. I got too impatient and I ended up pulling out one or more of the "sleeves" in the circuitboard. The functionality was improved, but it still wasn't "fixed".
#6 |
Simply Rotarded
Yeah, I actually killed one of the two switches. Before starting to desolder the second one I broke down and purchased a desoldering iron that made life easy the second time around. I did not pull any of the copper pieces out of the board. I also soldered bases into the places for the small relays, making future replacement plug and play.
#7 |
Simply Rotarded
![]() ![]() ![]() ![]() The small relays sit up a little higher than they did orginally, but they are swappable now.
LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! Last edited by LunchboxCritter; 01-31-2011 at 05:59 PM. |
#8 |
The wipers park by continuing to run as long as they see a grounded signal from the park circuit. If this signal is not there, the wipers will stop immediately when you shut the switch off. It is possible that it is the switch, but I would guess that it is a bad connection in the wiper motor or in the harness.
1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic) |
| Bookmarks |
