Old 01-28-2011, 12:14 AM   #1
low compression
low compression is on a distinguished road
s5 lim to s6 uim
Does anyone make the s5 lim to s6 uim adapter anymore. Im about ready to reassemble and am missing this important piece to the equation. Any help would be great. And yes i realized i put s5uim after posting... sorry for stupidity.
low compression is offline   Reply With Quote
Old 01-28-2011, 03:17 AM   #2
Fixed.
Old 01-28-2011, 08:55 AM   #3
They are not that hard to make yourself, or have a machine shop make one. Just give them an S5 and S6 gasket and say "make this work".
Old 01-28-2011, 06:39 PM   #4
low compression
How thick are most of them made? Is one inch enouch? I was contemplating making it myself but dont have a saw to make a strait cut on that thick of steel. I guess i could use clean edge of stock to be part you see and use cutoff wheel on other side.
Old 03-13-2011, 09:20 PM   #5
joeyfc3s
joeyfc3s's Avatar
joeyfc3s is on a distinguished road
No spacer
No need for a spacer,you are looking at a port matched S5 S6 combo.Some aluminum was added to the center runners and front area of the S6 manifold, then everything was port matched to perfection.
joeyfc3s is offline   Reply With Quote
