Old 01-20-2011, 08:07 PM   #1
IH8DSM
IH8DSM's Avatar
aluminum flywheel troubles
So i'm trying to install this aluminum flywheel on my car, trying being the keyword. I've got the rear counter weight on there correctly and the clutch fits but when i go to put the pressure plate on its got almost a half inch gap between the flywheel and the pressure plate. The flywheel is completely flat with no dowels in it, the clutch is recessed into the flywheels so its the pressure plate that is making it raised.
So heres my question do i need to use a aftermarket pressure plate, spacers and longer bolts or what? I've never installed a light weight flywheel on a rotary before and from everything I saw I thought it just bolted up and was good to go. I have no idea what kind of flywheel it is either.
Any help at this point would be appreciated
Old 01-20-2011, 09:24 PM   #2
FC Zach
FC Zach's Avatar
The prressuer plate should work on the flywheel if it is designed for the RX but if it's unknown of the flywheel compatibility to the RX then I'ld say your shootin in the dark.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 01-20-2011, 09:28 PM   #3
IH8DSM
IH8DSM's Avatar
I think i figured it out, I believe its a centerforce clutch, which is suppose to come with spacers and longer bolts which would make it work so i guess i need to figure out. if a aftermarket one will work with it without the spacers or not and go from there. Can't seem to find the spacers for sale any where, who knows might just do a rb one and put it on the old visa
Old 01-20-2011, 09:31 PM   #4
FC Zach
FC Zach's Avatar
The outermost portion of the clutch disc should be facing the pressure plate and it should also be mentioned that if there is a gap after tightening the pressure plate bolts
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 01-20-2011, 09:37 PM   #5
IH8DSM
IH8DSM's Avatar
yep everything was in there right just a huge gap
Old 01-20-2011, 09:43 PM   #6
FC Zach
FC Zach's Avatar
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 01-20-2011, 10:02 PM   #7
IH8DSM
IH8DSM's Avatar
tellin ya man i need the spacers haha its on the centerforce website
http://www.centerforce.com/mediafiles/I92MA001.pdf
Old 01-21-2011, 03:06 AM   #8
I run a Centerforce Dual-Friction on my '87 Turbo, and I did not need any spacers.
Are you, by chance, trying to install a non-turbo clutch onto a turbo flywheel?
Turbo flywheel is flat.
Non-turbo flywheel has raised pedestals.
You cannot swap clutches between the two...
Old 01-21-2011, 04:06 AM   #9
2gslse
If the clutch is installed right the raised side will be in the pressure plate not the flywheel and the pressure plate will sit off of the flywheel a bit until the bolts are tightened up(so the clutch is clamped down). Can you take a few pics of what you have to verify it is right? before tightening the pressure plate, you must use the line-up shaft that came with the clutch to center it with the pilot bearing. I have never seen any spacers on a clutch or pressure plate.
2006 VW TDI commuter
Old 01-21-2011, 06:40 AM   #10
IH8DSM
IH8DSM's Avatar
Yea Ted it's a non turbo the clutch fits in there fine and the bolt holes line up with my Na pressure plate, its because I'm trying to use a stock pressure plate. I'll take pics tonight but I think this one does use the spacers
Old 01-21-2011, 08:23 AM   #11
Okay, let me see if I got this right...
You're trying to use:
1) a non-turbo pressure plate
2) a non-turbo clutch disc
3) a turbo (aftermarket) aluminum flywheel
Is that combo correct?
Old 01-21-2011, 10:28 AM   #12
Lol.
Old 01-21-2011, 12:58 PM   #13
IH8DSM
IH8DSM's Avatar
Haha or I'm usin non turbo everything
Just measured stock flywheel vs aftermarket and were same size so again not a turbo flywheel ordering aftermarket pressure plate tommorow
