Old 01-07-2011, 11:32 AM   #1
sv51macross
sv51macross is on a distinguished road
S4 GXL LSD, confirmation
May have a lead on a S4 clutchie-LSD. Guy is local, and I want to make sure the pumpkin actually has a LSD inside it.
Question is, I don't know how a clutch-type unit behaves at rest. By turning/holding combinations of the input/output stubs, can I tell if there's a functioning LSD inside?
1990 Mazda RX-7 NA; Lucy, after the main antagonist from Elfin Lied.
Eventual plans? Something cyberpunk and spicy.
sv51macross is offline   Reply With Quote
Old 01-07-2011, 12:08 PM   #2
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
I know that mine has a tag on it, located around the drain plug or fill plug.
Look for that.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 01-07-2011, 12:28 PM   #3
sv51macross
Look for that.
A bit more detail please.
Old 01-07-2011, 04:31 PM   #4
N.RotaryTech
Home-brew Rotary
Old 01-07-2011, 04:38 PM   #5
sv51macross
Good enough for me. Yeah, I remember from my auto classes at CC clutchies take special diff oil.
[EDIT]: Ah, if the tag is missing, is there a mechanical way to tell if it's a LDS without cracking the pumpkin?
Old 01-08-2011, 02:09 AM   #6
Spin one side...
If the other side spins the same way, then there's some kinda locker in it.
If the other side spins the opposite way, it's open diff.
Now, this doesn't confirm if the LSD is in good, working condition...
It could be loose and out-of-spec, which basically means it reacts like an open diff when pushed hard.
There are friction plates that do wear down internally.
High mileage usually means worn LSD...
Old 01-08-2011, 04:07 AM   #7
sv51macross
Spin one side...
So, if I go to the local Mazda dealer, how much will they rape me, er, charge me, for replacement friction discs?
Old 01-08-2011, 05:05 AM   #8
I doubt any Mazda dealer would do the labor for it.
Looking at the Mazdatrix website:
http://www.mazdatrix.com/G8LSD.HTM
It looks like they charge around $350 just for the discs.
Find a good drivetrain shop locally, and they can do the work for you.
Assuming the prices from Mazdatrix, a fully rebuilt diff is going to cost you around $500 - $700 for parts and labor.
