Old 01-06-2011, 10:55 AM   #1
Crimping vs. Soldering
Throughout the years I've made various electrical connections (who with a 7 hasn't), but have never really known what I was doing other than some brief instructions from friends.
So my question is, what's the right way to connect two wires together?
I've read on the soldering vs. crimping debate and am leaning towards crimping being the proper way to connect two wires. However, I am finding all kinds of mixed results as to what kind of connectors to use, what kind of crimpers crimpers, insulated vs. non-insulated, etc. I've also ran across Posi-Tite connectors that seem quite interesting.
Maybe some scenarios will help.
I'm installing a new sensor in the engine bay and need to make a connection in the engine bay.
A second 12v outlet in the cabin. I have one wire running off an existing positive connection and one coming from the new outlet. How should I connect those two?
Installing a new EMS system. What kind of connections should I use there?
I prefer to leave everything so it's easily replaceable so not using a butt style connector is a preference. Although it would be good info to know the very best method, a budget method would also be good. I can't afford $400 crimpers and connectors that cost $20 each.
Old 01-06-2011, 11:23 AM   #2
If you call just about anyone that builds harness's, they should all tell you the same thing - CRIMP>SOLDER. In ANY circumstance. I questioned this even when dealing with the heavier gauge battery type cable... bigger than 8ga, and they say the same holds true. So I went out and dropped $80 on a lug crimper. MOST of the crimpers that you'll need are going to be around the $50 range if you hunt around. Most of the crimps I bought were from either Terminal Supply Co, Waytek. There was one co that had a REALLY nice buttsplice connector, I can't remember the name of it, I'll have to look at it when I'm in the garage next. The only time crimps are going to run you more than that are going to be in the mil-spec variety and I've been told that there are other/cheaper alternative than the Davis Manufacturing crimps.
So, you had mentioned the engine bay sensor. If at all possible I would cut the wire to length, and use the proper connector pins. You can usually crimp them with a Metri-pack style crimper. I use the metri-pak connector for metri and weather pack terminals. It can be found here
http://order.waytekwire.com/productd...%20PACK%20150/
but I know I searched around and found it for $80
If that doesn't work becuase the wire can't be extended, or its a mazda terminal, then you need to butt-splice them in. I personally, when wiring a car, use the un-insulated butt-splice stuff and just heat shrink it. I buy poly-olefin non insulated by the 100' spool and use that everywhere but the engine bay. Unless it's going to be loomed over with something. In the engine bay in an unprotected situation, I buy the adhesive lined stuff. If I'm wiring a boat, I use the retardedly expensive heat-shrink terminals. The only reason I do this is becuase most of the boats I wire are commercial and need to be coast-guard inspected. The CG generally doesn't approve anything that isn't individually heatshrunk unless it's an approved OE harness.
Connectors can be found here -
http://order.waytekwire.com/products...%20Connectors/
Crimps, these are the ones I'm not sure about, I paid $60 for them, will have to ge the name. It's a local co up in North Haven CT too. But, they're along these lines.
http://order.waytekwire.com/productd...IMPING%20TOOL/
except I paid $50. They do non-insulated butt-splice connectors. I also have a set of insulated butt-splice connectors for the marine stuff.
In your second situation, two wires on one side, one wire on the other. There is a special connector for that. Terminal supply co sells them as well and I believe a little cheaper. Either way, here is what they look like.
Basically, you would use one that has an 18-22ga (red) on one side, and a 14-16ga (blue) on the other. The factory wire would be cut and stripped. The additional wire would be spliced with the factory and then inserted into the blue cavity and crimped. Don't forget to put your heat-shrink on. Then the other side of the factory wire inserted into the red cavity and then crimped as well. Heat the shirnk and you're done.
I've had the solder vs crimp debate with alot of people. I've never had a crimp fail. I've had solder joints fail. I've also over crimped a wire and cut the strand, but that was only once.
Old 01-06-2011, 11:30 AM   #3
I use a set of MSD crimpers with the replacable dies.
With the three other option die sets, you can handle 90% of the crimp connections out there.
These include insulated and non-insulated - "Duestch" / "AMP lug" / "AMP pin".
This MSD crimper is also ratcheting, which will not release until you hit the proper compression.
The crimp tool + optional 3 sets of dies should come out to under $200.
(The crimp tool already comes with the "spark plug wire" set of dies.
Old 01-06-2011, 11:53 AM   #4
I second the crimping... if done properly. I prefer the un-insulated splices, crimp each side twice (using cheap crimpers), and heatshrink. Way cheaper and only a little more work than using heatshrink insulated connectors.
I'd like to find a good pair of crimpers ($50-100max) that I can be confident with and will hold up over time. Can the elctrical gurus post their favorites like Titanium and Reted above?
Old 01-06-2011, 12:39 PM   #5
Great info thus far!
What size heat shrink would be good to order?
1/4th for 8ga
3/16th for 10-14ga
1/8th for 16+ga?
Does anyone pack dielectrical grease in their connectors before crimping/heat shrinking?
Like these Ted?
https://www.msdignition.com/Products...et_Action.aspx
Old 01-06-2011, 02:17 PM   #6
Originally Posted by My5ABaby View Post
Yep, that's the ones I got.
Summit Racing or Jegs is going to give you the best price.
Make sure you order the optional dies.
AMP lug = butt connectors, spade / ring / male / female insulated
AMP pin = non-insulated
Deutsch = almost all your sensor pin connectors including Weatherpack in a pinch
The price sounds high, but it's a well-made tool and will make all your crimp connectors professional.
You're going to kick yourself for not getting it sooner.
Old 01-06-2011, 07:03 PM   #7
FC Zach
FC Zach's Avatar
I have those and absolutely love them. I use DMCs at work and think those are precise aand awesome but I just can't see spending that much money on a set for the house when the MSD set does almost the same at a fraction of the price.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 01-07-2011, 12:47 PM   #8
Yep.
I have several DMC crimpers (and turrets) just to handle the solid, machined Deutsch pins.
At over $200 a pop each crimper, it pricey, but they sure do a nice job!
Yes, the MSD crimp tool is a bargain compared to the DMC stuff.
If you look hard enough, there are even "generic" versions of the MSD crimp tool (I think Summit Racing makes one?) that's even cheaper if you're trying to save some bucks.
I've never been too bothered with changing the dies out myself.
Old 01-06-2011, 02:20 PM   #9
Not normally...
Weatherpack / Metripack connectors usually have silicone plugs in them.
Deustch also using a single silicone block to back the connector housing (no matter how many wires).
These are usually more than enough to handle automotive environs.
Old 01-06-2011, 12:49 PM   #10
Looking at the wiring, there's a lot of choices.
GPT primary wire
TWP primary wire
GXL cross-link wire
SGT battery wire
SGX battery wire
SXL cross-link wire
TXL cross-link wire
I found this:
When in doubt, use 125°C rated TXL, GXL, SXL, or SGX wire insulation for engine compartment and general wiring. The only difference between these is the thickness of the insulation and cost, with the thicker being the more expensive. They are all insulated with crosslinked polyethylene, which is almost as heat resistant as teflon, but cheaper and much tougher.
TXL is the wire used by vehicle manufacturers for most applications, and is the thinnest, lightest, and lowest cost of these insulations. It is tough and long lasting.
GXL is an intermediate insulation,with thickness and cost between TXL and SXL.
SXL is the second thickest of the crosslinked polyethylene insulations, and suggested for use in the heavier gauges, or where some additional protection from possible mechanical damage is needed.
SGX is the thickest of the crosslinked polyethylene insulations. SGX is particularly recommended for battery cable, because of the rather spectacular consequences of a shorted battery cable.
GPT is a PVC insulated wire rated at 85°C used for general chassis wiring, and should not be used in the engine compartment of your car according to the SAE J1128 spec. It's not as tough or heat resistant as TXL or GXL insulation, but it is considerably cheaper. This is the wire found in retail stores.
Sound about right?
If so, I would presumably go with TXL for most things, SXL in high heat areas (oxygen sensor wire or something), and SGX for battery cable?
Old 01-06-2011, 05:43 PM   #11
Ted's right, you'll kick yourself. I just didn't want to be bothered changing dies all the time. I figured in the past I would crimp a butt, then a pin.... than an insulated butt.... so why spend the time changing dies? i just one crimper for each and have loved them ever since.
I don't use the grease before crimping, but I do smear a little on the terminals before plugging them together.
Old 01-06-2011, 07:49 PM   #12
mazpower
Rawr Bearclaw
mazpower's Avatar
mazpower will become famous soon enough
This thread rocks.
I just ordered a set of the MSD crimpers with the dies. I've soldered in the past but after talking with Brian and opening my eyes to better ways of doing things, I'm gonna start crimping my harness connections.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
mazpower is offline   Reply With Quote
Old 01-07-2011, 11:11 AM   #13
According to that:
1/16 = 24, 22
3/32 = 20
1/8 = 18
3/16 = 16, 14, 12
1/4 = 10, 8
3/8 = 8, 6
1/2 = 6, 4
3/4 = 4, 2
1 = 2
Old 01-07-2011, 11:20 AM   #14
Future archive material. I've been meaning to create a new electrical bag. This will be a good start.
Old 01-07-2011, 11:42 AM   #15
Problem is the butt-connectors are thicker than the wire, so anything smaller than 1/8" is useless except to repair nicks in the sheathing. I buy 1/8", 1/4", and 1/2" and then heavy ass triple wall adhesive lined for battery cables
