Old 12-26-2010, 02:53 PM   #1
GtoRx7
Defined Autoworks promotional header offer
I have already found a couple people who are participating in this program, but open to more. 12a, 13b 6-port, 13b 4-port, 13b full P-port, Bridge port, ALL types will be considered to get a promotionally priced header.
The deal- Customers will purchase a Defined Autoworks prototype header that is built specifically for their engine setup/ car. Cost will be a very discounted price. If no extra power is found vs. the existing header, buyer can return for a full refund
What we need- Car must be using some type of programable ecu. so that the user has control over Air fuel, and timing. The Customer agrees to visit a dyno before and after new header install. The customer also must have knowledge of how to tune the vehicle, or has access to a tuner. Once the results are found, the user agrees to publish the results on forums.
Example header
Conclusion- And that is it! One heck of a deal, with less risk. Just post on here if you are interested. Header construction will begin in 2-3 weeks, cost will vary from $500-$600 depending on the setup. PM me for more details on your specific setup and cost.
Updated info
I should also add the following information about this program.
While originally posted as a R+D test, these headers are far from un-tested. We have been developing this technology and intake/exhaust length ratio for over 3 years now.
Proven results
Our 2 rotor street port, which is a 13b-re engine is producing 230rwhp. Using a identical approach our 3 rotor street port is over 350rwhp and the semi p-port 428rwhp.
Conclusion
So anyone interested, this is not a guinea pig test. This is a promotionally priced proven header, built to custom spec. We are excited to see the results from users running our equipment and thus promoting our name. In the off chance no extra power results, we provide a full refund. So if you are in the market for the most powerful header, consider ours.
Technical information
Material- Our headers use very expensive highest quality 321 stainless. 304 and 409 are lesser grades, and do not take rotary heat nearly as well. 321 also has better heat retention.
Tubing- The wall thickness is .060" or 1/16th. 2" o.d.
Weight- A finished header is between 12-17lbs depending on length. Each header uses a RB stainless flange.
Construction- Fully hand built and painstakingly TIG welded with back purging (nice and smooth on the inside).
Length- Primary tube length will vary between 30" and 65" depending on intake/ engine setup.
Dyno examples
DEFINED AUTOWORKS
Where concept meets results
Red 1970 Mazda R-100 with 10a
Black 1974 Mazda Rx4
Last edited by GtoRx7; 12-31-2010 at 01:54 AM. Reason: incorrect choice of wording on initial post
Old 12-26-2010, 11:07 PM   #2
PercentSevenC
Custom User Title
PercentSevenC's Avatar
That's a pretty-looking header. I almost wish I was still NA so I could help test.
Old 12-28-2010, 01:33 PM   #3
GtoRx7
Just build another n/a car
DEFINED AUTOWORKS
Old 12-30-2010, 11:42 PM   #4
orion84gsl
So, your not carb friendly? I have a streetported 4port 13B with a completely tuneable Sterling carb on it and an RB dual exhaust. I just had the engine rebuilt and have only just had it broken in before running into issues elsewhere. I am planning to get on the dyno in the spring.
Old 12-31-2010, 12:51 AM   #5
GtoRx7
We are carb friendly, I should have added that. Adding this type of header will most likely slightly change the air/fuel ratio. So to see the strongest gain, there needs to be some type of tuning capabilities in the system. And of course carbs can do that
DEFINED AUTOWORKS
Old 12-31-2010, 01:40 AM   #6
GtoRx7
updated
DEFINED AUTOWORKS
Old 12-31-2010, 10:46 AM   #7
RotorDad
Big Ugly
RotorDad's Avatar
Hmmm. Wouldn't mind trying a new header on my supercharged RX, but just not in my budget as of now.
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 01-07-2011, 01:54 AM   #8
GtoRx7
Here are some pics of our hand built collector that is on each of our headers sold. This version is for a 12a, 13b is similar just slightly larger throat diameter. I think this helps convey the differences of our collectors vs. any other header available.
DEFINED AUTOWORKS
