Go Back   Rotary Car Club > Tech Discussion > RX-7 2nd Gen Specific (1986-92) > Archives
Archives All the stickies in one place
Old 03-28-2008, 03:11 AM   #1
RETed's "HOW MUCH DOES FC STUFF WEIGH"
FEEL FREE TO ADD RELEVANT COMPONENT WEIGHTS. ANY COMMENTS WILL BE DELETED.
Ever really wondered what stuff weighs???
1989 GTUs rims (two measured): used, both include valve stems and balancing weights = 17.10# / 17.05#
GAB 16"x7" rims: new, silver, normal center, +32mm offset = 15.20#
1987 Turbo II stock pre-cat - used, O2 sensor attached = 13.50#
1987 non-turbo stock exhaust manifold - used = 16.75#
1987 Turbo II stock spare tire and rim - 24.85#
1987 Turbo II stock turbo: used, dirty, NO lines except for rubber lines on wastegate = 21.70#
Aluminum flywheel: used, stamped "MI" (Mueller Industry/Midway Industry?), NO counterweight, NO fasteners = 10.25#
1987 Turbo II stock flywheels (two measured): used, NO fasteners = 27.55# / 27.40#
1987 Turbo II stock front brake rotor: used, 10.9" (Mazda spec, NOT measured), rotor width measured at 5 different positions (5 lug positions) average 21.174mm (actual measured are 21.16mm, 21.18mm, 21.19mm, 21.18mm, 21.16mm; +/- 0.1mm) [Note: Mazda spec new is 22.00mm], used = 12.25#
K2RD Stage 1 brake kit rotor: 12.19" x 1.25", new, two piece steel rotor with aluminum hat, fasteners (safety wired) included = 11.40#
Racing Beat 3" downpipe: used, NO fasteners = 6.50#
Nippon Denso AC compressor: used, dirty, no fittings but black plastic caps on valves attached = 14.90#
1987 Turbo II stock steel hood: used, windshield spray nozzles and hoses attached, all underhood insulation and front rubber flaps attached, 5A blue paint = 51.85#
1987 Turbo II stock aluminum hood: used, NO windshield spray nozzles or hoses, all underhood insulation and front rubber flaps attached, hood stripped (NO primer base) and repainted yellow = 29.20#
Feel free to add anything you've weighed.
Old 03-28-2008, 07:41 AM   #2
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
While rebuilding my S4 NA engine, measured with bathroom scale...so...
Rotors: 9 lbs ea. = 18 lbs
Housings: 12 lbs ea. = 24 lbs
Eccentric shaft: 14 lbs
Front Iron: 22 lbs
Middle Iron: 27 lbs
Rear Iron: 26 lbs
Front cover: 4 lbs
Stationary gears: 6 lbs
Oil pan: 4 lbs
All engine bolts: 10 lbs
(oil pump, bearings, counter weight, chain & gears, engine pins, oil pick-up tube, oil filter pedestal, op sensor, etc.): 10 lbs
Total: 165 lbs
I guess this is considered a "short block".
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 03-28-2008, 02:03 PM   #3
cool_as_crap
BIIZZZAAAARRRRO
cool_as_crap's Avatar
cool_as_crap is on a distinguished road
Mustang rims (those 17"x8", 5 spoke) that everyone swaps onto their FC: 19.7 lbs.
cool_as_crap is offline   Reply With Quote
Old 03-28-2008, 06:01 PM   #4
jgrewe
FC door bars-- 12lbs ea
FC Master cyl/booster--11lbs
FC hatch frame--17lbs
Old 03-28-2008, 10:33 PM   #5
FirstRotaryExp
15x6.5 88 BBS convertible rims are about 10lbs each: Not counting tires nor centercaps.
Old 10-23-2008, 10:01 PM   #6
I started a list years ago, I'm trying to dig it up, here's some for now:
Stock front control arms w/ bushings & sleeve: 4lbs each
Power Antenna: 1.2lbs
Rear Speak towers (stock sheet metal on top of strut towers): 13.5lbs - for both sides
Racing Beat Front Sway Bar: 15lbs
Stock Front Sway bar from SE/Base: 9lbs
Old 10-27-2008, 09:24 PM   #7
Few more for the list:
S5 T2 Plastic under tray: 2.5lbs
S4 3-spoke steering wheel: 4lbs
S5 Center Armrest: 2.2lbs
S4 NA OEM Coilover assembly w/ stock rubber mount, OE KYB Strut and OE Springs: 15lbs
S4 Single Piston caliper: 7lbs
Old 03-13-2009, 12:11 AM   #8
anyone have the weight of an automatic counterweight (approx.) for those looking to know a total for aftermarket flywheels?
Old 03-13-2009, 07:20 AM   #9
I weighed both a LONG time ago.
There is very little difference between the series.
I can check the weights when I get back later this weekend?
Old 03-13-2009, 08:49 AM   #10
worse case ill weight the one i got off ebay when it comes in
Old 03-14-2009, 07:48 PM   #11
1987 Turbo II wheel - 23.4#
1989+ GTUs / Turbo II wheel - 17.0#
Prime Style 261 15"x8.5" wheel - 17.7#
Old 04-04-2009, 05:36 PM   #12
Trots*88TII-AE*
Trots*88TII-AE* is on a distinguished road
17 x 10 White Enkei RPF1's, with valve stem, no balancing weights or tires ~16# on a bathroom scale
Trots*88TII-AE* is offline   Reply With Quote
Old 05-05-2009, 12:32 PM   #13
misterstyx69
.drives like MrMagoo!
misterstyx69's Avatar
One SET of Stock Brake rotors..Front and Back,vented rotors..Total of all four is 48.5 Pounds~!.(for all you guys shipping Parts!).
Old 11-16-2009, 04:40 PM   #14
FCTII
FCTII is on a distinguished road
can anyone tell me how much a TII tans weighs?
FCTII is offline   Reply With Quote
Old 11-16-2009, 06:27 PM   #15
Black91n/a
Black91n/a is on a distinguished road
I weighed all the major assemblies of my TII transmission swap (trans, clutch/flywheel, driveshaft), but I won't have access to the numbers for another month and a bit (written on a piece of paper some ~4500kms away).
Black91n/a is offline   Reply With Quote
