Old 12-02-2010, 01:18 AM   #1
GtoRx7
F/S Defined Autoworks FD 13b half-bridge engine
Defined Auto 13b-rew half-bridge engine. 11,500 miles
Category: Engine - Complete Motors
Price: $2500
Private or Vendor Listing: Private Listing
Part Fits (you may select multiples): 1993+
Location (US State/Canada/Int): OH
Item Condition: Used
Here is a 13b-rew that we rebuilt 3 years ago, recently pulled from a customer car. He is going 20b. The engine has 11,500 miles + or - 80 miles.
Specs-
1994 engine block
Actual original rotating assembly (was not blown up when we rebuilt it)
Bridge port on the secondaries, Circuit port on the primaries
Fast spool turbo port on exhaust
OEM 2mm apex seals
Atkins Solid corner seals
New OEM bearings with correct clearancing
OEM water seals, and oil seals, and all rubber o-rings
New Oil pan from mazda when assembled
Comes with waterpump
Performance-
385 rwhp at 13psi with a T04E turbo with very safe tune. This same port style and build has produced 535rwhp with a GT35R. So its very capable to say the least. It always started quickly hot or cold (sign of great compression) And idle was rock solid.
Compression-
100psi front and rear
Using no battery charger, normal cranking speed, and shrader valve removed from standard compression checker.
Care and feeding-
Customer changed the oil every 1500 miles (everyone says this, but its actually true)
Always let it warm up before driving
Tuned by us (defined autoworks) from day 1
Never ran with less than 1/4 tank (no fuel starvation, or detonation)
Electromotive standalone controlled its whole life (most accurate timing you will get)
Always was pre-mixed 1 oz per gallon using amsoil 2 stroke.
Price- $2500 NON SHIPPED
$2800 shipped.
Keep in mind we charge $2750 just for the rebuild and half bridge. So this is a steal.
DEFINED AUTOWORKS
Where concept meets results
Red 1970 Mazda R-100 with 10a
Black 1974 Mazda Rx4
Old 12-04-2010, 02:10 AM   #2
GtoRx7
For Christmas price drop--- $2000 takes it
DEFINED AUTOWORKS
