Old 11-19-2010, 05:09 PM   #1
RX200013B
RX200013B's Avatar
RX200013B is on a distinguished road
help, looking to build a bad a$$ 6-port?
I'm looking for help on building a high hp 6-port N/A. all S4 parts. atkin's seals, ran by a haltech e6k. wanting the largest usable rev range. which i know is hard, but alway's wanted. this will be for complete PLAY. drag/auto-x, possible drift.
options
street port vs sec bridge vs full bridge?
s4 n/a vs s4t2 vs complete rew w/adaptor plate at block
aux port will have custom inserts to help ramp the air flow
looking for comments on how someone else would build one
as far as custom intake, help with the design and i will build it!
thanks Scott,(RX200013B)
ULTIMATE N/A
RX200013B is offline   Reply With Quote
Old 11-19-2010, 05:40 PM   #2
Your biggest power adder would be a custom intake. I think that the lower part of the factory one could be modified to be passable, but the upper part has to go.
I would recommend not using S4 parts, but S5. The rotors have better compression and are lighter.
What power levels are you looking for?
I have heard of an Aux Port Bridge, which will help the high end appreciably while maintaining some semblance of low end torque (not a bridge port until the sleeves open).
Unfortunately, I have never had the opportunity to build a maximum effort 6-port, but my mildly ported 4-port has 60 WHp and 60Wlb-ft on the best 6-port build I had (Haltech E6X, stock - polished intake manifold, port matched with custom cold air intake - no AFM, stock S4 block), Racing beat headers,
4-port vs. 6-port
216 WHp vs. 155 WHp
160 Wlb-ft vs. 100 Wlb-ft.
Short story is the the 4-port has a lot more potential than the 6-port.
The 4-port loses torque in the high revs because the stock ignition is weak past 6,000 RPM. The charging efficiency on the 6-port is so low that the ignition is plenty for it.
Old 11-19-2010, 06:25 PM   #3
TehMonkay
Get some TWM IDA style throttle bodies
You will get a better power band with a 4 port motor too.
Old 11-19-2010, 06:51 PM   #4
RX200013B
RX200013B's Avatar
do not have a 4-port motor.
custom intake? let's talk design?
ULTIMATE N/A
Old 11-23-2010, 10:18 PM   #5
There are several writeups on intake design.
I think that VEX's is probably the best for illustrations.
Vex's Intake manifold thread (building new)
Older Intake Manifold Thread (modifying stock)
Ideation
Vex's Build Thread
Thanks for the pointer Vex (I knew I had seen the graphics somewhere).
Old 11-24-2010, 12:45 PM   #6
may i suggest my build thread for cfd design iterations
Old 11-24-2010, 03:37 PM   #7
Originally Posted by Judge Ito
thanks! yes large gains.. regular bridgeports land anywhere in the 200 to 260rwhp.. this semi p-port with a bridgeport landed me 338rwhp using low compression rotors. that picture is a picture of my actual engine on my full tube chassis Rx3-Sp. The way I figure, If I use high comp. rotors and switch over to methanol. I would be well into a 380 to 400rwhp Naturally aspirated...with my semi-bridgeport set-up.. I would ad. revving takes very little effort..im using dual 55mm throttle bodies
If you want N/A power, search for Judge Ito.
Old 11-29-2010, 11:34 PM   #8
Unfortunately, my experience appears to indicate that higher compression rotors do not help the power.
Still, 338 WHp is awesome (probably on a Dynojet, which would make it approximately equivalent to Defined Autoworks' 430WHp 20B).
Old 11-30-2010, 04:42 PM   #9
RX200013B
RX200013B's Avatar
what about using a complete REW intake (w/ 1" adaptor plate)?
half-bridge on the sec ports only?
ULTIMATE N/A
Old 11-30-2010, 11:41 PM   #10
REW intake does not support 6PI for one thing. For another, I don't think the ports would line up well (never tried it with a 6-port, but I doubt that the ports are in the same location between an REW and a 6-port).
The stock LIM is fixable, it is the UIM that is hopeless. A custom UIM is not impossible, You could use parts from the stock UIM. It takes skill to TIG cast aluminum together and make it look decent, but it can be done. I was going to do that some day, but I seem to find enough to do.
Old 12-01-2010, 10:42 AM   #11
RX200013B
RX200013B's Avatar
the spacer is there to help with mounting and with the flow. as far as the REW mani supporting the 6pi, aux will be left open with a insert to ad in flow.
fair ?, is the REW intake good in any way for N/A performance?
ULTIMATE N/A
Old 12-01-2010, 01:51 PM   #12
I have a question I will interject here.
Has anyone used ditched the turbo's on an REW, and just run it NA?
I would be interested to see what it would do, either with stock rotors, or high compression rotors.
I am going to build another FC soon, and am going back to NA. Only every other car can be boosted
Old 12-01-2010, 04:08 PM   #13
I'm glad you've decided to get your good taste back and get an FC.
Old 12-01-2010, 11:30 PM   #14
I have heard that the RE intake is the best flowing intake for a 4-port.
I knew a guy who put down 202 WHp on a dynojet using an RE intake.
I think that GtoRX7's FC has an NA 13BRE in it at 230 WHp.
I would expect that 215-225 WHp is reasonable to expect NA.
The intake manifold-to-port matching will be so terrible, I would doubt that you would see any gains from the RE manifold.
I have heard of converting a 6-port to a 4-port by removing all the material between the ports, the sleeve, etc. I think this port would be way too big to make power at any reasonable speed or with the intake runner size that even an RE manifold has.
I am thinking that a custom intake (for the 6-port) with short runners or ITBs is your friend.
Old 12-03-2010, 11:10 AM   #15
RX200013B
RX200013B's Avatar
for ITB's, would 4 38mm throttle be big enough?
for a SP or even a half-bridge?
ULTIMATE N/A
