Old 11-13-2010, 02:04 AM   #1
Mazdabater
FC3S
Anyone reccomend me some fuel rails?
Hey guys, am putting a 13B-REW into my fc. And unfortunately can no longer use the billet fuel rails I had. Can anyone point me into the right direction of where to get some for an FD
Old 11-13-2010, 07:27 AM   #2
Garfinkles Motor Works
For the FD ,I mill the stock pri rail for sec injectors. I also make fittings for the stock rails that use SS braided lines Each fitting has three 0-rings unlike the stock damper and stock FPR with one o-ring .I also modify jic fittings to be brazed onto the fuel lines from the gas tank for the SS fuel lines . See my venders section for pictures .
Old 11-13-2010, 10:10 PM   #3
millertime
addicted to boost
millertime is on a distinguished road
for ease of installation on the stock LIM, the CJ motorsports rails are hard to beat. If you get the groundzero xcessive LIM, then just about any can be easy. The easiest way to do it is install the injectors and rail on the LIM BEFORE attaching it to the motor and dropping it in. You can either do what david recommends for the primaries or buy a top feed primary rail and do what I'm doing.
What ecu are you planning on using?
millertime is offline   Reply With Quote
Old 11-14-2010, 02:13 AM   #4
Mazdabater
FC3S
Yeah i did like the look of the CJ motorsports ones, one of the few that i found at a reasonable price. I'm already running a microtech LT10 at the moment, gonna just stick with it.
Old 11-14-2010, 07:25 AM   #5
I've got the CJ primary rail. I've been wanting to send my RE mani's to them to make a secondary modeled after thier REW rail.
Old 11-14-2010, 02:48 PM   #6
Mazdabater
FC3S
Yeah I was running some ones on the fc lim from mrparts.com.au that were good quality and cheap. He just sent me a pm on ausrotary saying he's just finished the fd kit and it's ready for production so I think I'll check how they look
