Old 11-08-2010, 05:40 PM   #1
dr50376272
dr50376272 is on a distinguished road
13b series 5 CAS help
How many teeth/windows/slots and what orientation does the CAS, crank trigger, and/or distributor wheel have?
dr50376272 is offline   Reply With Quote
Old 11-08-2010, 09:03 PM   #2
Physically, it's a 12 + 2 multitooth trigger.
It spins at half speed, so it's effectively a 12 + 1.
It is effectively two gears stacked on each other - sync gear and home gear.
It is triggered via magnetic pick-up's.
There are no windows or slots - it's not an optical trigger, if that's what you're asking for.
Orientation (for stock ECU) is dictated by procedure in the Factory Service Manual.
This CAS is particular to all FC 13B's (turbo or non-turbo, minus some funky Euro-spec distributor models) and all Cosmo 13B-RE and 20B.
They are all the same part number.
