Old 11-06-2010, 01:48 PM   #1
ZGN
Administrator
ZGN's Avatar
Nominations November Rotary of the Month - Any Rotary
This month is open for all rotary powered vehicles.
Only the first 10 entries that provide a minimum of 3 photos, interior, exterior and engine bay photo with description and mod list will be accepted.
Nominations will be closed on November 14th and voting will begin.
You can nominate anyone's rotary but you must be able to provide the requirements above.
Thanks for your nomination!
Kevin
Old 11-07-2010, 06:24 PM   #2
Rotr8
Rotr8 is on a distinguished road
Exterior
Summer wheels
Interior
Engine Bay
Mod List -
Engine and Exhaust
Pettit Racing Super Charger Stg.II CS
SR Altenator Pulley
RP SuperCat highflow(gutted-track)
RB Dual Resonated Midpipe
RB Catback Exhaust
BDC ported and polished Throttle Body
REmedy water pump
Magnecore 8.5mm plug wires
Mazsport cooling upgrade
Greddy oil pan
Optima Yellowtop battery
RMagic grounding wires
Mazsport Clutch Pedal bracket
Cooling mist Water/Meth injection kit
Custom Pettit secondary radiator built in the engine undercover
Fluid Motorsports carbon fiber oil catch can
Oil filter relocation kit
Racing Beat oil cooler hose set
ACT Prolite Flywheel
ACT flywheel counterwieght
ACT 6 puck sprung clutch-dead after 6K miles
-Installing Soon - Pettit Racing 13psi pulley
Suspension, Wheels, Tires and Brakes
Tein Type Flex Coilovers w EDFC
Mazdaspeed fr and rear strut bars
RB fr and rear sway bars
AP front and rear adjustable sway end links
AutoExe undercar bracing
Volk Racing SF Challenge fr 18x9, rear 18x10
Custom painted(one of a kind) 70%Matte Black barrell, Dark Quartz metallic spokes, polished details
Enkie GTC-01s 18x8.5 (track and winter)
Khumo Ecsta SPT 245/40R, 275/35R
Racing Brake 13" big brake kit with 4 pot aluminum calipers(Cutom colored Orange and Black)
RB 2 piece 13" curved open slot rotors front and rear
Stainless lines
Motul RBF 600 fluid
RB ET 500 pads
Interior, Exterior and Electronics
custom AutoExe SE-03c front bumper
AutoExe SE-03 hood
MazdaSpeed Sideskirts
Mazdaspeed rear skirt
KS Auto Burnout CF type2 chin spoiler(track bumper)
CF mirror covers
CF b-pillars
Holden Monaro wing w shaved 3rd brake light
Custom wing lip
AutoExe brake ducts and venturi's
shaved trunk emblems
3M 35% tint
Recaro Sportster CS's
AutoExe black buckskin wheel wrap
AFE Short Shifter
custom liscence plate frame
RB lower dash gauges
AutoExe CF Shift knob
CF dash shrowd
Tein EDFC
RX8Strakes FX Clear Corners
RX8Strakes Super White LED Running Lights
8000K Super White Xenons Headlamp bulbs
Stealth turn signals
Super White LED sidemarker lights
Coming soon custom front fenders
Coming soon APR GTC200 CF wing w/ 2.5 risers
Coming sooncustom pass thru trunk
Miscellaneous
Satin Black Roof panel
Painted TB and alternator semi gloss black
Custom colored RB BBK and 2 piece rotors
Headlight housings painted Semi-gloss Black
Rotr8 is offline   Reply With Quote
Old 11-08-2010, 08:51 AM   #3
Kane
All about the O2
Kane's Avatar
Kane is on a distinguished road
I was totally going to nominate you Rotr8... way to ruin it.
My 2007 Turbocharged RX8
Kane is offline   Reply With Quote
Old 11-09-2010, 06:04 AM   #4
I'm going to enter
Old 11-09-2010, 11:22 AM   #5
Rotr8
question is, with which car?
Old 11-09-2010, 12:31 PM   #6
RotorDad
Big Ugly
RotorDad's Avatar
Rotr8 very nice car man!
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 11-09-2010, 03:22 PM   #7
I guess the MB RX7..
Old 11-09-2010, 05:23 PM   #8
RotorDad
Big Ugly
RotorDad's Avatar
The car is looking good Herblenny. How about some interior shots.
PS3 ID: Rotordad
Old 11-09-2010, 11:47 PM   #9
Engine Bay
Interior
Engine:
-Petite Polished AST
-Koyo N-Flow Radiator
-Custom Carbon Fiber Cooling panel
-Fast acting Airtemp sensor
-Remote Start/pager/alarm/turbo timer
-BNR Stage 3 Twin Turbos
-Ported 13B-REW engine
-Custom Grounding kit
-polished Efini-Y pipe
-Polished upper intake manifold
-Polished 90mm Rotary Works Throttle body
-Polished Greddy elbow w/injector ports
-Apexi GT Spec FMIC
-Custom polished pipings By: www.BNRSupercars.com
-Constant tension T-blot clamps for IC pipings and Intakes.
-HKS seq. BOV
-HKS twinpower ignition amp
-Tanabe Catback
-SS Petit DP
-Apexi PowerFC
-Racing beat ignition wires
-FEED oil filler cap
-FEED coolant filler cap
-Added R1 Dual oil coolers
-Braille light battery
-Braille Verticle mounting kit
-FC Datalogit
-Unorthodox Alternator pulley (red)
-Unorthodox Power steering pulley(blue)
-Exedy Hyper Single Clutch Kit
-Simplified seq twin set up
-polished hardline intake pipes for secondary intake.
-Ported JDM Upper Intake manifold and polished by David Garfinkle. Also all the misc. vacuum ports have been welded shut and clean up and polished for cleaner look.
-Pettit Racing water pump pulley
-2 x 4 blade fan set up for better cooling
-HKS RS intake with KN filters
-Tweakit Racing tensioner pulley kit
Suspension:
-M2 launch kit
-Coilovers (About to install FEED coilovers)
-Racing Beat sway bar brace
-Racing Beat sway bars (front and rear)
-Garfinkle Motorworks Engine torque brace
-FEED front strut tower brace
-RZ larger front and rear brake calipers
-Hawk HP+ pads front and rear
-Newly sandblasted A-arms and other suspension parts
-Custom Garfinkle Motorwork cross drilled RZ rotors
-Braided SS brake lines
-Racing Beat sway bushings
-New Delrin bushings for all suspension parts
-Transmission brace
-Dragon's diff brace
-WORK XD9 18x10 +38 with 15mm spacer front and 20mm spacer rear
-Michelin PS2 255/35 front 295/30 rear
-Raceshop rollbar with much stronger rear strut tower brace.
Interior/Stereo:
-Converted Black interior - including, door panels, rear panels, head liner, seat belts, and black main carpet
-RZ floormats
-Rare moon roof interior cover
-JDM rear seats with panels, seat belts, and special rear carpet
-added R1 rear speaker pods for 7 speaker system
-Prosport boost, A/F, Fuel, Oil temp gauges
-Prosport center speaker pod
-Bride Exas III seats with Bride rails
-Nardi shift knob
-red leather stitching shift and ebrake boots
-LED interior lights
-Rare red stitch Nardi wheels
-Custom install of Protege cruise control to the Nardi wheel
-RE steering column pod with 52mm Prosport boost gauge
-JKL Engineering Carbon Fiber Gauge cluster, hood AC panel, shifter,etc (not overlay)
-JVC 7inch AV system
-New EL PowerFC commander and holder
-RE-A speedo cluster gauge
-FEED Carbon fiber rear trunk add on.
-Base model hatch cover
-added OEM fog light switch to turn FEED HID driving lights
Exterior:
-One off Feed Carbon Gas door (Shine Auto)
-Feed Type 2R front bumper
-Feed Carbon fiber canards
-Feed Carbon Fiber side skirts
-Feed wide front fenders
-FEED rear wide flares
-RE-A Carbon Fiber N1 hood
-Rotary Extreme hood dampers
-R-magic oil cooler ducts
-FEED front tow hook
-RE-Amemiya Carbon rear diffuser
-99 rear spoiler base
-AutoEXE carbon fiber rear spoiler deck
-MS replica 99 undertray
-Custom LED tail lights
-Odula carbon fiber 99 spoiler covers
-Custom rear bumper CF covers
-FEED head light cover
-rare glass moon roof
-SportTuner HID projector head lights
-LED signal lights in FEED signals
-HID FEED Signal lights
-Spirit R fender badges
-Efini front are rear badges
-Carbon look rear bumper lights
-Carbon fiber FEED gas door (one off made)
-APR Carbon Fiber side Mirrors
-Custom front canard add on
-Carbon Cooling panel (custom, made by me)
-LED bumper strip
-FEED signal light covers
-FEED door handles
-Carbon back of the door handle covers.
-Back Off 3rd light flasher
-ShineAuto rear tail light lip
-Feed bumper guard
-Custom rear tail lights
Old 11-10-2010, 02:01 AM   #10
JL1RX7
Thought the eight was bad ass. Well then you just destroyed that! Has to be one of the best looking third gen's I have ever seen. Wow is about all I can say
Old 11-10-2010, 01:54 PM   #11
RotorDad
Big Ugly
RotorDad's Avatar
Herblenny thanks for the overdose of FD greatness, interior is great!
PS3 ID: Rotordad
Old 11-11-2010, 01:45 AM   #12
13x
SinCityRotary
13x's Avatar
13x is on a distinguished road
holy crap batman
WHiV8 in the works!! May 2015
Email
13x is offline   Reply With Quote
Old 11-11-2010, 08:21 AM   #13
Thanks Guys... I still have few other things I need to update on this car.. .including my new FEED coilovers, tripoint sways, widefoot stuff, new big brake kit, etc.
Old 11-11-2010, 07:04 PM   #14
13x
SinCityRotary
13x's Avatar
Ok I am going to risk getting banned here but if no one else is going to say then I am
RINGER!!!
lmao
Email
Old 11-12-2010, 12:51 AM   #15
^^ LOL!
I know.. for that reason, I never entered in the past.. slight disadvantage for admin to run on these things.. as I'll ban otherwise
I usually pull myself off of the competition... so don't worry.
rotm
