Old 10-31-2010, 04:41 PM   #1
rx7mechusa
no no come on start plz?!
rx7mechusa's Avatar
rx7mechusa is on a distinguished road
Help Boosting issues 88 TII with S5 turbo
Hi i replaced the turbo on my S4 about 6 months ago have had no issues i used a s5 manifold and hotside and a garret T04B and made a hybrid turbo has worked beautifully untill about a week ago i cant boost above 3psi. Checked shaft play, all vac lines and caps, all inter-cooler connections and im at a loss. All emissions equipment has been removed and inter-cooler is a trust/greddy one that enters and exits on the same side to keep your P/S and A/C. Any recommendations or help would be greatly appreciated i think it may be the wastegate on the S5 hotside i can wiggle the mechanisim for the wastegate door. Again thanks for any help or recommendations
US ARMY-OH 58D(R) Helicopter Mechanic
Cars-
1988 10th AE
1993 Nissan Pathfinder (off road fun truck)
1999 GMC Suburban (10thAE personal transportation)
rx7mechusa is offline   Reply With Quote
Old 11-03-2010, 09:57 PM   #2
rxspeed7
The fan hit the shit!
rxspeed7's Avatar
you need to pressure test the system and check for boost leaks/vacuum leaks. Also you may want to check to make sure that your wastegate is properly connected and hasn't come disconnected from the flapper.
Zack.
Many ways you can get BDC'd
