Old 10-26-2010, 12:22 PM   #1
89fc3s
rotary powaaa
89fc3s's Avatar
89fc3s is on a distinguished road
metal wide fenders
I am want some +20 or +25 front fenders. So i can run some wide wheel/tire setup in the future. My only thing is i want to the front fenders to not be wider than the rear and be able to roll them. so who makes metal fronts?
89fc3s is offline   Reply With Quote
Old 10-26-2010, 01:53 PM   #2
Why do you want to roll the fenders and have larger fenders?
Old 10-26-2010, 03:20 PM   #3
No one does.
Old 10-26-2010, 04:27 PM   #4
89fc3s
rotary powaaa
89fc3s's Avatar
I want equality all around. i want to run either 9 or 9.5 all aound and i want the front fenders to be the same as rear do if i have to roll and pull the rear then i will have to do the same up front. but since there is no metal one FRP it is
Old 10-27-2010, 02:24 PM   #5
josh18_2k
get some shine fenders. they will let you run equal wheel/tire front and rear (255's on the right offset) and look OEM'ish (no crazy lines or vents or whatever).
if you plan to pull the rears, corksport fenders are your next best bet. wider than shine, fit pretty well, but have a vent.
and no, theres no wide metal fenders.
Old 10-27-2010, 09:16 PM   #6
89fc3s
rotary powaaa
89fc3s's Avatar
ive seen 255 front and 275 rear on stock fenders. i want 265 or 275 all around
