Old 10-24-2010, 09:29 PM   #1
Doc-1
Doc-1's Avatar
Rear Big Brake Kit==Help
I am looking for your opinions on a good rear big brake kit for the 3rd Gen. I will need to keep my e-brake on the kit. Looking forward to your insight
Old 10-25-2010, 07:36 AM   #2
Not many options Doc...
Choice one - RZ/Spirit R rear
Choice two - Racing Brake rear brake kit (slightly larger than RZ/Spirit R)
Choice three - Brembo kit secondary brake with any bbk.
Personally, I went with RZ kits (and I have RB kit)
Old 10-25-2010, 07:15 PM   #3
Doc-1
Doc-1's Avatar
Phil got a couple Questions
Phil
A Couple questions for a NUbbbb
First Where or whom is the best vendor to purchase said kits On the RZ/Spirit R where do you get replacement pads? That was an issue for me.
Second The reason and it is a bad one and I know it is.... that the 18's make the rear brakes look well kinda small. Since only about 20% of braking is done in the rear there is no real functional need other than they look small
Knowing me as you do which would you get for the old steed
AND LAST when can I purchase tickets for the up and coming DARGON????
Doc
Old 10-25-2010, 08:19 PM   #4
Alot of questions Doc
well, RZ/Spirit R's use the same pads as the 93-95s. They are pretty much the same rear caliper but brackets are extended so larger rotors can be used... I think I did a comparison of all the rotors on one of the threads.. Not sure where that is on this forum, but its there..
Here it is: http://rotarycarclub.com/rotary_foru...ight=RZ+rotors
DGRR 2011... Well, I'm still working on that as we speak.. I'm waiting to hear back from few people so once I get some answers, I'll announce it.
Old 10-25-2010, 09:26 PM   #5
Doc-1
Doc-1's Avatar
Whom did you get the RZ/Spirit R rear
kit from if I may ask. How are you doing as a Dad? Raised 4 myself
Old 10-26-2010, 06:28 AM   #6
Well, I bought fronts from someone else and rears from someone else.
But they can be bought brand new from Mazdacomp..
Old 10-26-2010, 11:53 PM   #7
Trout2
Trout2 is on a distinguished road
Unless you want to use a proportioning valve, you need front and rear brake that are designed to work together. Such as:
RZ/Spirit R front & rear
Racing Brake front & rear
Stoptech front with optional pistons to match RZ/Spirit R rear
Brembo front & rear
When I got the Sprint R/RZ rears I got the calipers from Rx7Store.net but if I they would have been available, I would have got the Racing Brake rear that retains the stock caliper and uses a bracket to move it our further. The 93 and Spirit R/RZ rear caliper is identical except for the mounting bracket (same size piston).
Jack
Trout2 is offline   Reply With Quote
Old 11-28-2010, 06:53 AM   #8
Richard Monster
Richard Monster is on a distinguished road
Where did you find a Brembo, or RB rear BBK that is for the FD? I've checked a bit (not claiming to have searched everywhere) and non-custom i.e. not in kit form BBK's for the rear are hard to come by. Greddy, Project Mu, Rotora, Endless, and Ksport are the only ones I've been able to find (As far as matched sets go, hence not counting Stop-Tech) . Of those, the Rotora's and Ksport's seem to be the easiest to get a hold of. This is less of a call out and more of a where did you find that so I can have more options.
Richard Monster is offline   Reply With Quote
Old 11-29-2010, 10:36 AM   #9
Trout2
Not sure to say exactly where Brembo rear kit can be found but RacingBrake.com has their kit on the web site. It uses larger rotors with a bracket to relocate the caliper.
Jack
Old 11-29-2010, 12:41 PM   #10
To_Slow
In a couple of months I will have a kit with handbrake option that will work with a separate caliper like so in the pic.
My link
Old 11-29-2010, 01:43 PM   #11
Are you making these? I like!!!!
Old 11-29-2010, 06:08 PM   #12
Yeah that's pretty cool To Slow! That would really free up some options for the rear brakes for people that want to keep the e-brake function. I might be interested in something like that myself.
Old 11-29-2010, 07:50 PM   #13
Brent
Sua Sponte
Brent's Avatar
Soooooo... no one has said they have to have these or their cars will fail or they will get better braking out of them(only as good as your tires), but I encounter so many people that have this misconception, I thought I'd have some disorganized thoughts here
RZ/Spirit R essentially do the exact same thing as the racing brake rears. They bring the pad out farther to create more torque. Pad size/brake pad contact patch is the same. As someone that has ran all configurations extensiviely on track, I will relay a of my thoughts:
1. If you aren't extensively tracking your car and have been for a long time(ie 20+ track days), you don't need larger brakes, period. You may want them because they look cool, but you don't need them. Certainly not for street use. If you want to stop faster... get better/stickier tires and a more aggressive brake pad. Stock brakes with aggressive pads will exceed the limit of almost any street tire.
2. Between the 93-95, RZ/Spirit R's, and Racing Brake, the additional stopping power is negligible at best. The where the RZ and RB help, is larger rotors. Eventually, you will crack rotors on the 93-95 set up if you are running 20-30 minute sessions on track AND not cooling down your brakes afterward(ie driving around the paddock). You will also have the same problem if you run cross drilled rotors and track your car, regardless of how big your brakes are. What is also given is that you are getting the most out of your brakes. Most guys starting out on track aren't anywhere near the limits of their brakes to do this. I just put my RZ/spirit R rears on my yellow FD(stoptech fronts) for an event this next weekend... there is no distinguishable stopping difference between the RZ/Spirit R's, the 93-95's, or the RB's other than the rotors won't crack like the 93-95's.
3. If you are experiencing "brake" fade where the pedal goes to the floor, you are actually experiencing fluid fade where your fluid is boiling at the caliper. There are alot of reasons for this. Most of the time, it's because you have never changed your brake fluid in the car since the factory in Japan put it in the car in 93
4. The other part of the equation is matching your caliper pistons with your master cylinders, or in the stock FD's case, the master cylinder. Generally stock is fine, but sometimes the pedal can be a little soft on certain FD's. The 929 master cylinder seems to be a good solution if, after you change your calipers, you encounter this issue.
Fritz Flynn, who has tracked FD's for more than 10 years now and I would argue has more seat time than any FD owner on track(and prob. pushes the car more than anyone I've ever encountered), currently runs the stock 93-95 rears on his current track car(been tracking it for about 4 years) with the brembo fronts.
In conclusion, if you want them to just have them on your car and your money is burning a hole in your pocket... I can respect that... but don't think you HAVE to have them.
Old 11-30-2010, 08:46 AM   #14
BigIslandSevens
BigIslandSevens's Avatar
That is great info Brent. I am going to replace my M/c with the 929 next year. My pedal is too soft even when bled fully. ( I think you actually made note of that at RA this year)Brakes and tires are my biggest things to tend to for next year.
Does the factory M/C have a integrated proprtioning valve? Wondering if my valve I have in line is hampering my rears more than needed.
Old 12-01-2010, 03:17 AM   #15
Garfinkles Motor Works
I have the 929 MC and it feels tight, very firm .I reworked the unit so it is a drop in install. No new lines or rebending lines .And yes it is polished .
