Old 10-21-2010, 11:41 AM   #1
dr50376272
dr50376272 is on a distinguished road
crank angle
series 5 13b turbo
what after market computers allow the crank angle sensor to be used?
can i simply use the old mazda 13b turbo computer in my rx4 coupe?
i want to keep the crank angle sensor
thanks !
im off to beat some horses !
dr50376272 is offline   Reply With Quote
Old 10-21-2010, 10:31 PM   #2
Check out the aftermarket ECU or tuning forums here. I can tell you that the Haltech, Microtech, MoTec (if you are crazy rich) and Megasquirt will all use the factory CAS.
It is a 24 + 2 (home) sensor.
Old 10-21-2010, 11:33 PM   #3
Depending on how crazy you want to go with the engine, you could use the stock ECU to control the entire engine. If you're doing a transplant though I would give some serious thought to building a new harness with some bulkjead connectors. This way if you have plans to upgrade the ecu later in life all you need to do is build a strait harness from the ECU to the firewall.
Old 10-22-2010, 06:50 AM   #4
What TTT means is Bulkhead connectors, or cannon plugs.
