Old 10-20-2010, 09:17 PM   #1
To_Slow
FS.2000cc Bosch injectors
Up for sale 2000cc injectors i have like 100 injectors..
These are not modified to flow that amount they come standard from Bosch.
Bosch EV14 Injector with top adapter. Flow rate 2000 cc /min @3 bar, 8.5 ohm. Sumitomo (NDCON1) connector, total lenght 74 mm, distance between O-rings 61 mm. 1600 cc /2 bar, 2400 cc /4 bar.
Much cheaper than any site out there.
The same injectors from Injector Dynamics 2000cc
Price per 185.00$ Shipped...
My link
Old 11-10-2010, 04:07 PM   #2
millertime
addicted to boost
millertime is on a distinguished road
these are high impedance correct? Do they come with the pigtails? Do you also have the 725s or 1000s? Would you do a discount if I purchased 2 1000s and 2 2000s?
millertime is offline   Reply With Quote
Old 11-10-2010, 07:04 PM   #3
To_Slow
Yes high impedance,pigtaills are extra 4.00$ per.
1000cc can have them in a couple of days 98.00 per .
Sorry i cannot do deals they are pretty cheap..
My link
Old 12-17-2010, 05:45 AM   #4
To_Slow
2000cc 180.00 shipped with tails
1000cc 90.00 shipped with tails
My link
Old 12-17-2010, 10:48 AM   #5
As long as these are the exact same injectors and setups, that's a better deal than I've found anywhere else, and I just bought a set not too long ago haha.
Old 12-17-2010, 12:21 PM   #6
To_Slow
Thanks... yes the same...
My link
Old 12-17-2010, 05:00 PM   #7
neit_jnf
Boricua!
if one buys them in pairs, are they flow matched? do they include flow and latency numbers?
Old 01-14-2011, 10:15 PM   #8
sickofpistons
sickofpistons's Avatar
sickofpistons is an unknown quantity at this point
What kind of deal can you get for 2-750 and 2-1000 LI injectors with clips and tails? LMKS thanks Joshua.
sickofpistons is offline   Reply With Quote
Old 01-15-2011, 10:02 AM   #9
To_Slow
All injectors are flow matched from the factory. I have tested over 200.... 2000cc injectors back to back in house. Not even a 1% variation.
Yes, they wil come with a flow sheet that will show they are matching flow rates.
My link
Old 01-15-2011, 10:03 AM   #10
To_Slow
You got mail...
My link
Old 01-15-2011, 11:55 AM   #11
MaD^94Rx7
MaD^94Rx7 is on a distinguished road
so the injectors you areoffering are plug & play for the fd3s just like the ones being sold by injector dynamics? practicaly what I'm asking is: are these exactly the same thing at a cheaper price?
MaD^94Rx7 is offline   Reply With Quote
Old 01-15-2011, 05:16 PM   #12
To_Slow
Injector Dynamics 2000cc are Manufactured by: Bosch
Then ID just re brands them as there injector.
The part # for Bosch 2000cc injector is # 0280158821
That is correct, i provide the same injectors as ID at a realistic price, not the over inflated price of 220.00 per.
Yes they identical
Coil Resistance: 9.1 Ohms / High Impedance
Dead Time: 0.45ms at 14 volts
Static Flow Rate @ 43.5 PSI ( 300kPa ) w/Gas: 2200 cc/min = 210 lb/hr
Static Flow Rate @ 58 PSI ( 400kPa ) w/Gas: 2550 cc/min = 240 lb/hr
Static Flow Rate @ 78.5 PSI ( 500kPa ) w/Gas: 2865 cc/min = 273 lb/hr
Static Flow Rate @ 88 PSI ( 600kPa ) w/Gas: 3155 cc/min = 300 lb/hr
Static Flow Rate @ 101.5PSI ( 700kPa ) w/Gas: 3350 cc/min = 320 lb/hr
Connector: Denso / Sumitomo
Injector Length: O-Ring to O-Ring: 1.5. / 37.5 mm
Injector Body Diameter: 16mm
O-Ring: 14.5mm Viton
Acceptable Fuels: Gas/Petrol, alcohol/methanol, E85, CNG
Yes they are plug in play with no need of resistors, with the help of a aftermarket ECU like PFC Etc..
Thanks
My link
Old 03-10-2011, 04:40 PM   #13
To_Slow
Sold out..
My link
Old 03-28-2011, 09:35 AM   #14
2a_ron
2a_ron is on a distinguished road
ID matches the injectors based on flow AND dead times, do you do the same? Do you provide data with them? If not, they are NOT the same.
2a_ron is offline   Reply With Quote
Old 03-28-2011, 09:40 AM   #15
To_Slow
For a injector 2000cc NGI from Bosch that cost 60.00 + The ID flow/dead times at 150.00+....
I don't think the dead time /flow sheet is worth the 150.00+
I have looked at customer's flow /dat sheet from ID for 2000cc injectors they are all the same, what stops ID from just coping the same flow sheet and sending it out with the same injectors...
I'm not pointing fingers or making the above a true actual fact, other than taking ID word that they have been flowed/dead times etc.. I hope you understand my point of view...
But yes Bosch NIG 2000cc injectors are the same as ID injectors,, the flow sheet is not the same....
Thanks
My link
