Old 10-09-2010, 02:13 AM   #1
JustJeff
JustJeff's Avatar
Plain Jane OEM nothing to see here rebuild
I'm bored and new to RCC so I figured I'd post up pics of where my car is...let everyone get to know me, what I'm doing...etc etc.
History on the car, it's a JDM 13B swapped 89 vert. I daily drove the engine with no rebuild for something like 3 years. I had put the typical mods on the car
13B turbo and tranny
-engine supplied by Atkins/swap done by AIM Tuning
N370 ECU and modified N/A harness
S4 differential
RB REV TII full exhaust
FCD
Cosmo MAF
FD fuel pump
550/800 primary/secondary injectors
FD alt
airpump removed
Tokico blues and Tein springs
and a pretty nice upper-end but lowkey stereo system
Mine is the one in the background
I was running with no aftermarket control (boost, fuel, etc), but was running rich and rarely romped on the gas. I had been waiting for Rtek S5 TII chips to come out of beta. BUT detonated the engine and blew the front housing.
Old 10-09-2010, 02:35 AM   #2
JustJeff
JustJeff's Avatar
This is my first rebuild of any kind, so at least so far I'm keeping the rebuild OEM. Not doing any porting or other modifications. Though if I found some used FD stationary gears I'd do that and modify the e-shaft oil jets. I need to replace my stat gear bearings, so if I found some used FD gears in good shape I'd consider that modification
Apex seal corner broke on front rotor
It spun around a couple of times, took out the housing and rotor
Had a hard time getting pics of apex groove that got damaged
Old 10-09-2010, 02:39 AM   #3
JustJeff
JustJeff's Avatar
IIRC the bad apex seal groove was still within FSM specs for overall clearance. BUT it varied by like .002 or .003 from the good side to the damaged side. I was afraid that much difference from one end to the other would cause problems so the rotor was replaced.
Old 10-09-2010, 02:41 AM   #4
JustJeff
JustJeff's Avatar
Cool pic I got while snapping pics of the teardown and cleanup
Old 10-09-2010, 02:45 AM   #5
JustJeff
JustJeff's Avatar
Front Stat gear
Rear Stat gear
Old 10-09-2010, 05:06 AM   #6
Something to think about...
The front FD3S stat gear is machined differently than the FC3S stat gears.
You might need to change out all the "front guts" in the oil cover to FD3S parts - thrust bearing plates x2, Torrington bearings x2, spacer.
Old 10-09-2010, 10:20 AM   #7
JustJeff
JustJeff's Avatar
^thanks for the heads up Ted, from what I had read so far I thought I could use just the gears and didn't need any other modifications other than extending the e-shaft jet grooves.
This is why I created the thread, in case I miss something. I'll be sure to reread the info I had found before doing anything. If there is any doubt I'll keep the stat gears I already have. I'm not building a high rev, high output engine so I really don't need the hardened stat gears.
One question, are the Cosmo 13B-RE gears a direct swap? I'm still researching that one, but had been told they are hardened but a direct swap...but they also do NOT have the better bearings that the FD and RX-8 have.
Just to complete the conversation for anyone who is searching for related info. I had read conflicting info about using RX8 gears. Some said they are a direct swap and other said you need to shave off like .001 on 13B e-shaft to accommodate the gear.
Old 10-09-2010, 10:42 AM   #8
JustJeff
JustJeff's Avatar
Another updated
Before removing the engine I had random smoking exhaust, but couldn't find the source. I first noticed while looking for a hose leaking coolant. I had replaced my water pump and had a coolant leak that seemed to only leak while the car was running and hot. I drove the car around the block to heat it up and while still running I jacked up the front. Found it was a clamp I hadn't tightened down enough so it only leaked when it got hot.
Point of that story is that while the car was running and jacked up it created a smoke screen. In general it had a smokey exhaust that I only noticed when looking at the tailpipes. But from that day on it would occasionally smoke screen while driving.
Turns out my turbo had thrust play in it. I measured by pressing the shaft as far away as possible with a dial indicator on the shaft. Then pushed it all the way the opposite way so I'd get a reading of the full play. It was like .001-.002 IIRC
That has been replaced with a S5 that has no play.
Old 10-09-2010, 10:54 AM   #9
JustJeff
JustJeff's Avatar
I've gotten bored while waiting for the rebuild to come together so I painted. I wanted something I hadn't seen done before so I went with black and copper
The rear housing in the pic is the bad housing that will be replaced. I pushed everything together to get a better idea how it would look and if I liked it
I'm still not sure if I'll keep that paint or not. It might be too different. I also may have the intakes powder coated rather than rattle can painted.
I may repaint the irons and front cover silver or aluminum. And have also considered going full fanboy and making the intakes white with a rising sun painted over them. Who knows might even airbrush some artsy BS on there.
Old 10-09-2010, 12:16 PM   #10
I can't confirm on the Cosmo stat gears...
The Cosmo (20B only?) runs a 3-window bearing on the stat gears.
The 3 windows are slotted.
Mazda Comp (now Mazdaspeed) used to sell them as "Mazda competition bearings" back in the day.
The FD3S 13B-REW runs a 9-window bearing - 9 drilled holes throughout the stat gear bearing.
It's arguable whether which is better, but the 13B-REW ones are the newest design and therefore arguably better.
Sorry, I can't confirm either.
I don't mess with RX-8 stuff.
For me, the RX-8 wasn't turbo'd so why try and use "NA" parts in our turbo'd application?
Old 10-09-2010, 02:46 PM   #11
JustJeff
JustJeff's Avatar
^Thanks again for the feedback
I saw pics of the 13B RE gears and they look the exact same as 13B, no difference in the bearing either. From what I was told the only difference is the gear is hardened.
I doubt I'll change the stat gears or anything else internal. OEM was serving me well enough. I was happy with external mods and 12psi boost. I don't want to do anything on the engine thats irreversible and will affect driveability and reliability. I want the engine to be able to daily drive if needed, pass e'check if needed.
Old 10-10-2010, 04:36 PM   #12
I have done the exact same thing with a vert... jspecc TII, na harness, 550,750s... and I got the Rtek 2.0 just recently... for a basically stock setup it works great by helping fine tune things, monitor stock sensors, and gets rid of the need for a FCD. if getting a bigger turbo I would get a little nervous about not having a more powerful standalone though as you can't boost over 14 and I'd like the ability to use faster reacting sensors and remove the MAF.
It does do some pretty cool things though... fyi I have no emissions, hence the non CEL codes. but it datalogs fairly decent and accepts my wideband signal.
Old 10-10-2010, 11:32 PM   #13
RotorDad
Big Ugly
RotorDad's Avatar
Pulled from Mazdatrix who actually recommend the Renesis stationary gears. They are already hardend.
"If using the RX8 rear gear in an earlier 13b engine, you must add sealant where the rear gear o-ring WOULD be. There is no groove to hold the o-ring because the Renesis engine mounts the o-ring in the side housing rather than on the gear. We recommend using Hylomar, but a THIN layer of silicone sealant will also suffice."
The 3 window bearing IMO opinion is just as good as the REW multi window.
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 10-11-2010, 03:37 PM   #14
JustJeff
JustJeff's Avatar
I'm going with a 1.7, once the car is back on the road and I'm not paying the bills for the rebuild I'll start thinking about sending my old turbo to BNR and other upgrades. Though most of my modifications I want are reliability and longevity mods. I'm eyeballing Sohn's MOP mod ATM
http://rotaryaviation.com/oil_injector_pump_adaptors.htm
I'm curious which pins you swapped on the N/A harness, not the VDI pin at the ECU, but IIRC there are two pins that need swapped further up the harness on the two plugs that attach to the dash harness. I've got two spare N/A harnesses and compared them to my modified harness...I can't find any wires different.
Old 10-11-2010, 03:39 PM   #15
JustJeff
JustJeff's Avatar
Thanks Dad, I remember having read that but those thoughts fell on the backburner. Thanks for bringing that up. I believe it was on Nopistons I read people using RX8 gears.
