Old 09-29-2010, 10:27 PM   #1
FC Lower arm bar
Inspired by this thread and the evidence in hand in that thread I decided to build a lower arm bar. Dr. Overkill performed the procedure
Started out with two hiem joints, 8" of opposite threaded tube, two spare brackets, 3"x12" 1/8" steel, and some very hard to find 1x2 anodized aluminum tubing.
First I layed the brakets flat against some cardboard. I find beer boxes to be fantstic. Tracing the curve of the bracket down to the bottom. Cut that curve out and tape it to the bracket itself. Now, with the bracket level, place a level ontop of the bracket and trace a line against the cardboard. Put the hiem joint ontop of the carboard and make a judgement call as to where it should be. Don't forget about the 14 mm bolthead underneath. Transfer that cut out to steel and cut it out. I would repeat that process or at the very least, test it on ALL the brackets. Next clean everything up.
With the bracket bolted to your workbench bust out the magnetic level and stick the new pieces on the bottom of the level and line them up with the bracket. It's important to always have a true and level workbench. It makes things SOOOOO much easier. Put a few tacks on but only a few, we need to make sure its properly aligned.
After you are certain that it is true, a few tacks on the back and run a bead.
Becuase I thought it would be good on the back as well. Not really needed but I did it anyway. Cleaned up the beads on the front as well. Don't know why, they were purty.
Old 09-29-2010, 10:29 PM   #2
Drill a 3/4" hole and viola. What I generally do when I need to get throught two pieces of metal like that is drill a pilot hole, 1/8" or so through both and check for square and true, then go for the big 3/4" hole. Easy to adjust an 1/8", difficult to adjust a 3/4"
Starting with the 1x2x1/8" 6061 tubing and the opposite thread section of pipe. In reality all I really needed to do was order a length of threaded pipe the correct length (about 21") and been done with it. But then it wouldn't be original. Plus I'm building a front & rear strut bar out of the same material so now it all matches
A few measurements later and out came the jig saw. You'll see why in a minute.
I spent ALOT of time filing down the inside of the tube to more closely match the arc of the threaded tub. Almost 3/16" of an inch gap is just too much so it had to be filed down. Thinking ahead before you cut too is also key. I almost ruined that piece by getting a little excited.
Old 09-29-2010, 10:29 PM   #3
Everything aligned and clamped down on the bench. Again, sooooo nice to have a good bench. Level, true and you can weld right on it.
One great bead, one shitty bead.
After a lil more welding and some grinding - DONE! Time to instal.
Installed on the car. So nice and easy to get on. Swap the brakets and instal one hiem joint to the bracket snugly. Put the other in the rough spot where it needs to be and rotate the entire brace until it falls into line. Tighten both bolts down and give the bar a turn or too more to load it up and jam down the lock nuts. Pre-load is a good thing sometimes.
Old 09-30-2010, 04:46 AM   #4
RotorDad
Big Ugly
RotorDad's Avatar
Another nice piece.
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 10-03-2010, 11:54 PM   #5
Garfinkles Motor Works
Another nice piece to say the least. What is next I will tune in soon . I need to learn how to put pictures on here because I have made a few parts as well . Keep it comming this is better than peanut butter .
Old 10-04-2010, 06:12 AM   #6
Wouldn't you get more rigidity out of a strictly welded bar... though if you're using aluminum it will deform.
Good how-to.
Old 12-02-2010, 06:02 PM   #7
Brian! Fix your pics!!
Old 03-16-2011, 02:01 AM   #8
TheAbsence
TheAbsence is on a distinguished road
^ Bump for rehosting the pictures somewhere
TheAbsence is offline   Reply With Quote
Old 03-16-2011, 07:30 AM   #9
Pics were originally on TeamFC3S.org and I don't have them on this machine.... I might be able to dig them up on the onld archiac Dell I have in the closet...
Old 03-21-2011, 01:37 PM   #10
aaronoverholser
In search of knowledge.
aaronoverholser is on a distinguished road
Where can I view pics of the piece you built?
Zoom Zoom- The only car on the road that is truly something different... the RX7!
aaronoverholser is offline   Reply With Quote
Old 03-21-2011, 04:47 PM   #11
TeamFC3S.org which appears to be down. If I ever get the chance I'll dig the old comp up and pilfer the pictures from it and rehost them here. Can't make any promises on when it'll be though.
Old 05-08-2011, 01:12 PM   #12
Thumper
Backyard Mechanic
Thumper's Avatar
Thumper is on a distinguished road
TT is there any way you can fix the pics on this thread and the thread on your strut brace.
Thumper is offline   Reply With Quote
Old 05-08-2011, 02:16 PM   #13
ModDimension
ModDimension's Avatar
ModDimension is on a distinguished road
+1 I wanna see pics please
ModDimension is offline   Reply With Quote
Old 05-08-2011, 03:56 PM   #14
Id have to bust out the old OLD computer and see if they're still there. Kinda not had the time with 10+ hr days 6-7 days a week. I'll get there eventually..... or just get intouch with tony farkas and tell him to get teamfc3s back online
Old 05-09-2012, 12:21 AM   #15
Sharingan 19
My money is on you getting to that dusty crap box....
