Old 03-26-2008, 08:08 AM   #1
jgrewe
FS: Fiberglass hatch frame w/lexan window, $400
I've been making these frames for a while for the racers and thought I'd post them here. They could be adapted to work with hinges but you would still need to have some way of holding the edges down tight. The whole thing weighs about 14-15 pounds. Frame w/ lexan installed, $425
St Pete, Fl 33708
Last edited by jgrewe; 01-08-2017 at 12:57 AM. Reason: price change because of materials increase
Old 03-26-2008, 05:24 PM   #2
Very nice. Free bump!
Old 03-27-2008, 11:27 AM   #3
jerd_hambone
Senior Member/Lounge Rat
jerd_hambone's Avatar
How do you hold them down? A pin system? Directly bolted down?
I might be interested in one.
1986 Luxury Package
1987 Luxury Package (sold)
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
Old 03-27-2008, 09:10 PM   #4
jgrewe
See the little silver slotted thing in the elbo area of the frame? There are 7 of them around the frame, 2 on top, 3 across the bottom(holes) and 1 on each side. They latch with a quarter turn.
Old 03-28-2008, 08:41 PM   #5
jerd_hambone
I like, I like, maybe give me a couple of weeks, and I'll be all over one.
What would shipping be to 40737?
1986 Luxury Package
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
Old 03-28-2008, 09:44 PM   #6
DriftingFC
DriftingFC is on a distinguished road
Are those Dzus fasteners? That is a trick ass piece. I am so going to be lookin at gettin one. These will be available for a while?
DriftingFC is offline   Reply With Quote
Old 03-29-2008, 08:23 AM   #7
jgrewe
Yep, Dzus fasteners.
I forgot to mention the whole thing weighs only 15lbs. The frame is about 4 and the lexan is 11. Compare that to 57lbs for the stock one that doesn't have a wiper. The stock frame alone is 17lbs.
Better buy one now, limited production piece!!!!!!! Just kidding, I'll always have the mold laying around, let me know when you're ready.
Here is a couple pics of how I hold it down.
Old 06-08-2008, 01:18 AM   #8
JunpoweR
JunpoweR is an unknown quantity at this point
How much with the fastners?
I might get 2 of these.
--^v--JunpoweR--^v--
"90 GTUs Crystal White *GT35 WB TA Project*
"90 GTUs Brilliant Black *Restoration*
1984 GSL-SE *Daily*
JunpoweR is offline   Reply With Quote
Old 06-12-2008, 07:48 AM   #9
jgrewe
With the fasteners would only be about $15-20 more depending on how many you want and what kind of mounting tabs you want. I've also had people use a combination of dzus, hood pins and stock hinges. I should probably post a shot of that set up. They used the stock hinges and hood pins to hold the straps that SCCA requires as well as holding things down. Then the dzus fasteners were used to hold the "elbo" part on the sides in tight.
It would be best to put the fasteners on after you get the tabs mounted for best fit but shipping you the stuff in a bag would be no big deal.
Old 07-06-2008, 09:15 PM   #10
Wolf7
Wolf7 is on a distinguished road
How much louder is the lexan + fglass than a stock hatch? Any problems with water leaks?
Wolf7 is offline   Reply With Quote
Old 07-07-2008, 05:16 PM   #11
jgrewe
Exhaust and road noise come right through it, I can't say how much more because I have not run a car with a stock hatch with the engine and exhaust I have on the car. I just have to worry about being under 103db so my car is very loud.
I don't run a hatch seal(weighs too much!) so I get water in the car. I suppose you could run one and I could seal up the window to hatch mating surface when I build it but its really a pure race part. I would really have to take a look at how close the frame is to the chassis on the underside to see if a stock seal would help. Its made to look like a stock piece from the outside only so its held only by the dzus tabs not resting on the body opening.
For use on the street, its possible, where there is a will, there is a way. If you want to lose a bunch of weight of your street car I can help you brainstorm to make it work for you.
Old 07-07-2008, 05:33 PM   #12
That hatch is still Bad Ass. I would rock one, but it is a little overkill on my FC!
Free love!!
Old 09-28-2008, 09:22 PM   #13
FortyfiveD
Amudextrious
FortyfiveD is on a distinguished road
Do you have pics of the underside of the hatch I'm very interested and would like to see how the hatch itself looks. thank you.
FortyfiveD is offline   Reply With Quote
Old 09-29-2008, 09:32 AM   #14
jgrewe
Here are a couple close ups. The one with the wider green foam core is the top across the roof area. It shows how I attach the strap required by SCCA with dzus fastener in the area of the stock hinge. The one with the narrow foam core is the bottom/back edge. I can get a full shot tonight and post it this evening.
You can also see the rivet backing washers that help hold the lexan to the frame.
This has been tested up to about 150mph many times if that hasn't been mentioned before.
Old 11-04-2008, 06:22 PM   #15
|)arkspeed7
|)arkspeed7 is on a distinguished road
how can I order one of these guys? I like the 1/4 turn fasteners in the first pic, I want mine like that.
|)arkspeed7 is offline   Reply With Quote
