Old 09-20-2010, 08:35 AM   #1
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Premix oil reservoir recommendations
I'm thinking about doing an external premix by modding the MOP on my 12a.
I'm thinking I can go to the pull-apart and grab a big plastic, mountable
container from something to use as the reservoir. Heres my requirements:
1. Has to be safe for 2 stroke oil, won't dissolve or degrade with the oil in it.
2. I'd like something about 1/2 gallon so I don't have to constantly fill it.
3. Easy convertion to hook an output hose to it.
4. Nice to have would be brackets.
I'm thinking I can start by looking at wiper fluid reservoirs because they are
usually pretty large but I'm worried they may not stand up to the oil.
Anyway, let the ideas fly. I'm open to any make, any model I can find in a
pull-apart here locally.
Old 09-20-2010, 09:51 AM   #2
t_g_farrell
Waffles - hmmm good
I just stumbled on a Polaris XPLORER 400 2 stroke reservoir on ebay. Looked up the
specs and it holds 2 qts, so its pretty good size. Looks like it has a level sensor
as well.
Old 09-20-2010, 09:05 PM   #3
9krpmrx8
SARX + Boosted = Win
9krpmrx8 is on a distinguished road
I got this made (puts drain, nipples, etc. where you want) by a guy on ebay for like $25.00. If you need his info let me know, its very thick and well made. The cap is great as well.
DSC_0035 by 9krpmrx8, on Flickr
I also had this one that I bought at Advanced Autoparts for $10.00. The cap sucks a bit but the reservoir is good. I just got a four point strut bar so I have to rework my setup a bit now.
sohn by 9krpmrx8, on Flickr
9krpmrx8 is offline   Reply With Quote
Old 09-25-2010, 12:05 AM   #4
j_tso
j_tso is on a distinguished road
That looks like a universal aftermarket coolant overflow tank. They say not to use them for oil because it will degrade the plastic over a short period of time.
j_tso is offline   Reply With Quote
Old 09-25-2010, 07:45 AM   #5
t_g_farrell
Waffles - hmmm good
Yeah , I've been reading up on it and you need something that can stand
up to 2 cycle oil. Just any ole coolant or wiper tank won't do, they will
disintegrate in a matter of months.
Thats why I started looking at motorcycles, snowmobiles and ATVs. Turns
out the ATVs seem to have pretty large tanks on them. I think I'll get the
Polaris ATV tank I saw on ebay. Once I do I'll do a writeup on how to
mod the MOP for an external tank. I know its been done before but I think
a more recent one is in order for the 1st gen.
Old 09-27-2010, 09:57 AM   #6
9krpmrx8
Meh, thats BS,it's been over a year, still good as new.
Old 09-27-2010, 10:06 AM   #7
t_g_farrell
Waffles - hmmm good
I think j_tso was referring to the first 2 cycle reservoir you had from autozone.
The custom one you have now I bet is made to standup to 2 cycle oil.
Old 09-30-2010, 04:57 PM   #8
9krpmrx8
I'm not running the custom one, I only used it a short time because the custom one does not fit with my new strut bar. I am using the cheapy
Old 10-01-2010, 01:29 AM   #9
Trout2
Trout2 is on a distinguished road
Chuck Westbrook found a nice tank for a weed eater at Sears.
Jack
Trout2 is offline   Reply With Quote
Old 01-04-2011, 01:38 PM   #10
Looks like a well-made tank setup, how much premix will it hold? I'm looking to do this project on my FC. Please share the ebay contact/store info when you have a chance.
Thanks,
Pete
Old 01-05-2011, 12:42 AM   #11
Garfinkles Motor Works
I made my tank for the 3rd gen out of sheet metal brazed together with a large fine threaded bolt for the cap .It is vented through the cap .The thing is shaped to fit the space and holds over three qts. I have made acouple out of 4 inch exhaust tubing and mounted them where the air pump mounts .I used the first gen oilfiller tube and plastic cap for the filling port .
Old 01-05-2011, 12:56 AM   #12
If you're talking about the white tank, I think I have the same exact one and I got it for about $12 at US Plastics, I got the vented lid too though and I think that was several dollars itself. I got some fittings, drilled the hole and tapped it, put some thread sealant on the threads and installed the fitting. Works like a charm, and they're good for oils too so it should be fine.
EDIT: Here is mine. Pretty sure they're exactly the same.
http://rotarycarclub.com/rotary_foru...52&postcount=7
Old 01-05-2011, 12:56 AM   #13
Prodigy
Half bubble off plumb
Prodigy's Avatar
With Brazing, (I have never done it) but is it similar to oxyacetylene welding by chance, where you have the two pieces, and join them by the filler rod...?
Its something I might have to look into for the future.... hmmmm
J.
360 gamertag: Tichlis
Old 01-05-2011, 02:21 AM   #14
Brazing uses the gases and the filler rod is flux coated brazing rod .I have been using it to make motorcycle gas tanks oil tanks ,repair parts . make fuel rail fittings attach sheet metal to mold motorcycle frames ect ect for over 45 years .
Old 02-14-2011, 12:48 PM   #15
msimonov
msimonov is on a distinguished road
Tim, Donnie (AWS) has a nice external chrome oil tank on his car. It may be a little pricy but, it is nice looking solution for an external oil tank through the OMP.
msimonov is offline   Reply With Quote
