Old 09-19-2010, 09:10 AM   #1
wayne
wayne is on a distinguished road
How to check for fuel?
Hi there! Just need some advice - having trouble starting my Mazda RX7 FD3S. The motor swings freely but does not want to fire. Have changed plugs and checked spark, which is all ok, but would like to check if it is getting fuel. Have no idea on how to do this. Can anyone help???? Also, what else should I check?
wayne is offline   Reply With Quote
Old 09-20-2010, 11:45 PM   #2
Ratjar
Ratjar is on a distinguished road
can you hear the fuel pump kick on? check the ignition fuse and the fuel pump fuse. try jumping it as well, if it has low compression it needs a strong spark to start.
Ratjar is offline   Reply With Quote
Old 09-21-2010, 04:34 PM   #3
cewrx7r1
The Judge
Maybe it is due to you having a gay engine that SWINGS freely instead of cranking.
If you go to page F-97 of the field service manual and start reading, you may learn some things. At lease do the F/P to ground test and you should be able to hear fuel flow.
If you do not know anything about manual, go to:
http://foxed.ca/foxed/index.php?page=rx7manual
